Author Topic: can i use copper for my brakelines?  (Read 1930 times)
Offline antogoof
  • bbm mk2 g60
« on: 10 October 2009, 12:59 »
had a problem over the last week, i have put 16v prakes on my 8v mk2. i have goodridge hoses to put on and the nut on the union in the front wheelarch is solid............
i mean solid.
tried wd40, brake cleaner and heat, none of which worked. using an 11mm spanner on the nut is a turd as well as if you give it too much grief it will round the nut.
i was going to cut the brake pipe and re flare it, but the flaring tools i have been looking at are about £80 for steel pipe.
i can buy a kit for less than £35 to re do the brake lines in copper with all the unions, cutter, pipe bender and flaring tool, but i am a bit dubious as to the quality as the exsisting lines are steel.
would copper be ok to use instead of steel?
mk2 bright blue met bits wanted in north west.
Offline Horney
Re: can i use copper for my brakelines?
« Reply #1 on: 10 October 2009, 13:04 »
Yeah I've used copper pipes on all my Golfs when I've had to replace them.
nick
Offline antogoof
  • bbm mk2 g60
« Reply #2 on: 10 October 2009, 13:12 »
i dont really know what probs it could possibly cause but i was just a bit concerned as it has steel lines and copper is a bit weaker?
thans nick btw :smiley:
Offline jase16gti
« Reply #3 on: 10 October 2009, 13:14 »
iv always use copper pipes, it is a lot easier to work with than steel and never corrode
Offline Horney
« Reply #4 on: 10 October 2009, 13:15 »
copper lines I believe are a bit thicker to cope with the pressure but other than that I don't think there's any difference.
nick
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #5 on: 10 October 2009, 13:22 »
I wipe a bit of copper grease on them as you do get surface rust
Offline molegti
« Reply #6 on: 10 October 2009, 13:28 »
"copper" brake lines are usually kunifer and surely that has to be an improvement over steel?
Offline antogoof
  • bbm mk2 g60
« Reply #7 on: 10 October 2009, 13:35 »
sound. its a done deal then, copper it is.
thanks for all the replies. :smiley:
Offline Ben Lessani
« Reply #8 on: 10 October 2009, 13:39 »
Copper is the standard for replacement pipe.
Steel is manufacturers line - and is VERY difficult to flare, it cracks easily.
Offline richard s
« Reply #9 on: 10 October 2009, 20:16 »
i use copper/nickel mix pipe as its a bit stiffer and i think it shapes a bit nicer than copper
