Author Topic: Sorry if its been asked before, Gti 8v problems  (Read 1577 times)
Offline bob.wills
« on: 10 October 2009, 12:36 »
Guys i just spent two hours searching to no luck  :sad:, Got a few little problems with it.
  • One the wipers don't have a quick wipe?
    You can push the stalk down and it goes intermitant but there is only one click and no clicks up? Any idea's?
  • Two how do i turn the rear wiper off.
  • Also the hand brake light stays on?
  • And was wondering how to set up my coilovers so i can go as low as possiable with standard wheels (don't know if i will need to remove the arches)
Thanks for any help guys  :wink:
P.s were is the best place to look for a vento front end ( tried ebay and local Scappy)
Offline Khare
  • The bear that khares
Re: Sorry if its been asked before, Gti 8v problems
« Reply #1 on: 10 October 2009, 12:45 »
1) for quick wipe just push up to the point just before it clicks up, if you know what I mean.
2) to turn it off you press it in again, the same as to get it going.
3) handbrake light is also connected to brake fluid level, either your brake fluid is very low (replace ASAP) or the handbrake switch is sticking, which means removing it and cleaning it.
4) to go as low as possible just wind the coilovers down, you could roll the arches, or get some arch extensions, or get lower profile rubber.
Offline VR6-Joe
« Reply #2 on: 10 October 2009, 12:48 »
Oh no
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Khare
« Reply #3 on: 10 October 2009, 12:49 »
best place for vento front is forums. Here, edition38, clubgti.
Offline bob.wills
« Reply #4 on: 10 October 2009, 13:17 »
Cheers guys,
Khare, i know how to lower them just want to be as low as i can with out rubbing the arches? How easy is it to roll the arches? Would i be able to do it myself?
Offline Khare
« Reply #5 on: 10 October 2009, 13:20 »
you need a special tool to roll the arches.
Offline VR6-Joe
« Reply #6 on: 10 October 2009, 13:23 »
Or use a heat gun to heat up the paint (prevents it cracking so I'm told) and use a f*cking great hammer to bash the f*ck out of them!
It's what I did lol!
Although with standard rims I wouldn't expect much scrubbage. I've got 7x16's with 195/45 tyres, 15mm adapters front and 20mm rear. My front coilovers are wound down ALL the way off the threads and the fronts never rub! Rear is set a bit higher as the wheels stick out further which causes scrubbage :(
Offline bob.wills
« Reply #7 on: 10 October 2009, 13:24 »
 :sad:
ok well will it have less rubbing if i remove the arches? Oh do mk2 arches fit?
Offline VR6-Joe
« Reply #8 on: 10 October 2009, 13:26 »
Just realised you have a GTI so you've got those ghey plastic arch trims which also require a bit of trimming if you roll your arches, but it is possible. I was 100mm down on 17's when I had my GTI rep. If you remove them completely then it gives you a couple of mm extra clearance
No Mk2 arches don't fit lol
Good luck
Offline shepgti
