Author Topic: N/S/F wheel seems to be closer to arch than the O/S/F?????? HELP!!  (Read 1045 times)
Offline AliBailey88
since ive fitted my 18s and lowerd 35mm on shocks and springs ive noticed that the n/s/f wheels is closer to the rear of the arch than the o/s/f is, causing rubbing when locking left so the wheel is touching the the back of the n/s/f arch.
Is this accident damage from the past or is this normal?
ive set up all the tracking front to rear with the laser alignment at work so this isnt the issue.
any help would be great!
ta
Offline snap-on
castor/camber angle check needed
Offline AliBailey88
this cant be adjusted on a mk4 though can it?
Sounds like something is out of line.
Offline Rhyso
camber can be adjusted
Offline AliBailey88
camber is not really the issue, its the caster angle, i would say its pointing rearward from the vertical axis.
Offline Steve_PD
check out Phil.O's thread a couple weeks ago, he had the same problem after fitting shocks and springs and it turned out his car was involved in a accident and because of cheap copy parts his was rubbing
