Author Topic: Water Flange Help Needed , Please ,  (Read 965 times)
Offline WYATT
« on: 07 October 2009, 22:32 »
Alrite , i have got a 1.8 carb golf , i've fitted the oil cooler from the GTI , but on the water flange from the standard carb setup it has two water ways and three sensor's , this is the one on the front of the Cylindar head once you open the bonnet up ,
But now i have fitted the correct flange to do with the oil cooler it only has two sensor clip in bits with the 3 water ways , so now im left with a sensor left out and this is the temp gauge one for the dash display , could i maybe remove one of the other sensor's but i bet they all have importants roles to play,
The part i need i doubt they make would have 3 water ways and 3 sensor clip in bits ?
Cheers Joe
Offline Diamond Hell
  • Opinions я Us
Re: Water Flange Help Needed , Please ,
« Reply #1 on: 08 October 2009, 08:39 »
Heh, flange.
One of your temp sensors/switches does carb stuff IIRC (which I might not).
If you're running a Weber it may be that you can swap one of them out.  Check where in the loom the wires out of the sensors go.
« Reply #2 on: 08 October 2009, 11:59 »
The red one is for the autochoke and the grey is for the inlet manifold heater.  at a push you can get away without the inlet heater, as you often see people shaving their hedgehogs.  One solution is to get a side flange for a MK2/3 8v equipped with aircon, this has a sensor fitting in it you can use.
As DH says if you have a webber then you wont need the autochoke one anyway.
