Author Topic: Intermittent indicator fault; driving me mad  (Read 997 times)
Offline willm
« on: 07 October 2009, 13:25 »
Hi chaps, first post here so I hope I'm not treading on any toes...
I have a clean and excellent Mk.3 which has done 20,000 miles in the last year with no problems... except one.
In wet weather, when the side- or headlights are on, the left indicator occasionally becomes 'sticky'. It then produces a steady (not flashing) light and may continue to do so even with the indicator switch returned to the 'off' position. If so, the only way to 'clear' it is to switch the lights off.
My excellent, well-regarded local garage has had three goes at sorting it. Clearly there is a short between the indicator and main beam circuits somewhere that is sensitive to moisture, but it's pretty damned evasive.
I'd happily take it to a specialist if someone wanted to recommend one around Bristol, Eastleigh/Winchester, or Chichester. But I'd be even happier if someone said "That happened to me, too" and told me which wiring loom or junction box to check.
Best, Will
Offline axewielder
  • 95 dragon 8v
Re: Intermittent indicator fault; driving me mad
« Reply #1 on: 07 October 2009, 14:08 »
Best Autocentre in winchester are alright, one of the mechs has a mk3+ another has had lots of mk2s
gtigolfthree
« Reply #2 on: 07 October 2009, 16:03 »
Hi, welcome to the site do a google search for an auto electrician in your area could guess all day long at that one but without doing visual and multimeter tests would just be guessing.
Offline MK3TDi1996
« Reply #3 on: 07 October 2009, 20:56 »
how do!
probbably no help as yours seems to be an issue when wet but mine did this for the first few days of ownership until i discovered it was just the relay acting up!  Pull it out and tap it a few times, worked for me!
« Reply #4 on: 08 October 2009, 08:59 »
I would substitute the relay 1st and see if it helps.
