Author Topic: Bigger valves?  (Read 3016 times)
Offline e11ie
Bigger valves?
« on: 07 October 2009, 11:56 »
Machine shop just rang me, i dropped my head off (1.8 8v PB) there to get the guides and seats done, they say the vlaves i have given them dont fit the head...
I brought brand new valves from Euro car parts, part number 308 44 0431
Spec says 38.1mm valve diameter
Definitly the right one for my engine as it says compatible for PB
However comparing them to the valves i took out they are about 1mm smaller all the way around in diameter
There is a what looks like a part number on the top of the valve i took out.....L - C26 601C
Is it possible the previous owner has uprated to bigger valves or have i been mugged and its not even a PB head (I really dont have a clue when it comes to engine nitty gritty!)
If so does anyone know where I can get these valves from or shall I just re-use the ones I got (was going to soak the head in diesal when i got it back anyway...can i put these in too?)
Offline DOA
Re: Bigger valves?
« Reply #1 on: 07 October 2009, 17:48 »
Stock PB inlet valves are 40mm diameter, all earlier engines use 38mm ones so ECP have sold you the wrong parts.
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: Bigger valves?
« Reply #2 on: 07 October 2009, 18:43 »
Soak the head in diesel? I thought diesel in a petrol engine caused carnage or is it the other way around?
If you need 4 valves we might have stock at work. let me check tomorrow!  :smiley:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline molegti
Re: Bigger valves?
« Reply #3 on: 07 October 2009, 20:13 »
Diesel makes a pretty good parts washer solution from what I can gather. Its just a light oil so theres nothing in the engine its self it can damage.
The whole wrong fuel thing is all about damaging the fuelling system cannot think how an engine can be hurt either way. Petrol is bad in a diesel car because it rots the seals and doesn't provide lubrication from what I understand.
Offline e11ie
Re: Bigger valves?
« Reply #4 on: 07 October 2009, 22:46 »
So even though it includes my date and engine code on their website its their fault?....Just want to make sure so when I phone up again (the second mistake they have made on the one order!!) I can be sure that they are the ones in the wrong not me!
These are the ones i got..... http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_1.8_1990/p/Car-Parts/Engine-Parts/Engine-Parts/Cam-and-Valve-Train/?308440431&1&07c7ea0b763f77391c1fba3436b0a9f8296243e1
Cheers for all your help guys (again  :rolleyes: )
Offline Khare
  • The bear that khares
Re: Bigger valves?
« Reply #5 on: 07 October 2009, 22:48 »
those are for a 1.6 (and I think 1.8 driver) head. 38mm inlet (i think 36mm exhaust). GTI has 40mm inlet and 38mm exhaust as said before, so yeah, deffo the wrong valve size was given to you.
Offline e11ie
Re: Bigger valves?
« Reply #6 on: 07 October 2009, 22:55 »
ok cheers for clearing that up....proper annoying because it says its for the 8v gti, PB engine...spent ages making sure I had narrowed it down to the right ones!
Well...least it isnt my fault!
Thank you  :smiley:
Offline Khare
Re: Bigger valves?
« Reply #7 on: 07 October 2009, 23:04 »
maybe the earlier 8v engines (not sure if the engine code was PB) had smaller valves, same as the other 8v engines.
Offline danny_p
Re: Bigger valves?
« Reply #8 on: 08 October 2009, 00:29 »
carb engines  had 38mm valves.   gti's are all 40mm iirc
all the VW's have gone bar 1.
Offline DOA
Re: Bigger valves?
« Reply #9 on: 08 October 2009, 07:12 »
Its even in the haynes book of lies, PB and PF use 40mm inlets, all other 1.6 and 1.8 8 valves use 38mm.
