Author Topic: stiff gears when starting from cold?  (Read 2684 times)
Offline Mr A
« on: 06 October 2009, 20:47 »
has anyone else experienced stiff gears when starting the car from cold.
its annoying, im going to spray white grease on the gear linkages, (hope that helps)
how do i remove the leather cover around the gear knob without damaging it, i want to spray white grease there too.
also my clutch is really really low, this is also annoying, can i have this adjusted?
any help or advice is appreciated. many thanks
- 1999 MkIV Golf TDi -
*  Repairs Needed = Faulty Passenger Door Module, VAGCOM set-up, Rear Wiper, Rust Treatment, Rear Wiper Motor, Battery or Glow Plugs, Stubby Aerial,
Offline northeast_gti-t
  • "1.8T AGU"
Re: stiff gears when starting from cold?
« Reply #1 on: 06 October 2009, 20:52 »
it may well be because your gearbox oil is the incorrect grade but it will be a little stiff as its cold before you move off could try putting it into 1st and then 2nd and then neutral and then 1st
the leather cover just unclips by pulling up and you can't adjust the clutch as such as its hydraulic
2000 Mkiv GTi 1.8T AGU
Offline nadlad
  • Building Surveyor MRICS
« Reply #2 on: 06 October 2009, 21:10 »
wd40?
<<<Big Build Thread>>>
Offline Mr A
« Reply #3 on: 07 October 2009, 10:29 »
this morning was painful, the cold weather wouldnt allow me to change gears outside my house, it took a few minutes and then it was stiff for about 10mins-20mins, getting looser the longer i was driving.
extreamly annoying!!
help
Offline jake
« Reply #4 on: 07 October 2009, 11:36 »
Hi mate
To be honest with you it is not an uncommon problem, it is due to the temperature of the oil in the gearbox, in the morning the oil is still cold, so as the minutes go on the oil will become warmer and do its job alot more efficiently, loads of cars i have driven have suffered from this, Its not a major issue.
If its really annoying , perhaps give the gearbox a fresh drop of oil
Jake
Offline Mr A
« Reply #5 on: 17 October 2009, 13:30 »
 :grin:  Good news everyone, i've finally sorted my stiff gear problem
took car to mates garage and he drained the gearbox oil out for me.
He noticed it was unusually smelly (colour was dark brown), i purchased the correct ATF gearbox oil (which was red and very thin).
he topped it up with 2litres as recommended by dealers.
I tested it out immediately and all is now well, no more sleepless nights.
I also noticed a small leak in my radiator, he highly recommended i try and use K-Seal to repair the leak.
so i added that to the coolant tank, plus water plus G ++ coolant.
I hope that does the trick, fingers crossed. Has anyone used K-Seal in the past?
Offline jonnyturbo
« Reply #6 on: 17 October 2009, 19:49 »
Yep i used it on my previous car its ok not a permenant fix tho IMO
Offline Phil_M
« Reply #7 on: 17 October 2009, 21:01 »
Gearbox oil is normally very smelly horrible fowl smell  :sick:
GOLF 1.9T AGU TD05H 18G
http://smg.photobucket.com/albums/v218/pipmann30/GOLF%20GTI%20%20TURBO/?albumview=slideshow
Front wheel drive monster 0-60mph in under 5sec 0-100mph in 10sec
