Author Topic: Ferrari 348 wheels on mk3?  (Read 2052 times)
Offline tomcat
« on: 06 October 2009, 20:44 »
Hi all
Thinking of putting Ferrari 348 wheels on my mk3 but have no idea if they will fit, ideally I'd like a full set to have the 9" wide on the rear and the 7.5" on the front.
But would settle for 4 x 7.5" if that makes the difference between being able to do this or not. :undecided:
7.5" + 49mm offset -  Front
9" + 68mm offset - Rear
Also the PCD is 5 108 and the centre bore is 67.
Tom
Re: Ferrari 348 wheels on mk3?
« Reply #1 on: 06 October 2009, 20:46 »
Yes you could fit them with adaptors, 30mm rear and 20mm front, biggest problem will be finding the wheels plus the adaptors will need to be custom made.
Offline shepgti
« Reply #2 on: 06 October 2009, 20:50 »
would also need spigot rings for the centre bore
« Reply #3 on: 06 October 2009, 20:54 »
Good point  :smiley: unless the adaptors will do it.
Offline tomcat
« Reply #4 on: 06 October 2009, 21:15 »
Thanks peeps
I found some 5x100 to 5x108 adapters on american ebay. they say they are 1.5 inches thick, sounds a bit too much to me but is that ok for space.
Also the 20mm and 30mm measurements you give, are they for the 9 inch wide wheels on the back or the 7.5 inch?
Don't want to search for months and make a very expensive mistake.
Thanks
Tom :smiley:
« Reply #5 on: 06 October 2009, 21:37 »
Thanks peeps
Thanks
Tom :smiley:
That was based on 9" rears, 7.5 all round might be better for clearance.
