Author Topic: Dashboard messages...  (Read 2810 times)
Offline Danger Shepster
« on: 05 October 2009, 19:54 »
Hi
I'm new to the wonderful world of Golfs & have just got a 1998 mk3 8v which I love.....it came with every single receipt from new but no owners handbook & there's a message that comes on when I turn on the ignition which looked like 'in 01' to start with but has recently changed to 'in 02'....what does it mean & should I be worried that some sort of big-end implosion is imminent?!
Obviously this might be a normal message if you're used to Golfs but I normally drive a Mini so having any sort of dashboard is a miracle of modern technology....the car is fitted with a full-closure alarm & immobiliser. To clarify it only comes on when I turn the ignition on & disappears when I switch on the engine.
Cheers.
« Last Edit: 05 October 2009, 20:42 by Danger Shepster »
Offline Diamond Hell
  • Opinions я Us
Re: Dashboard messages...
« Reply #1 on: 06 October 2009, 08:43 »
You have 'Inspection Service 1' and 'Inspection Service 2' indicators which are triggered as the miles roll on.
Unless it's been serviced (and the indicators not switched off), your car needs servicing.
« Reply #2 on: 06 October 2009, 08:54 »
Thanks for that....the car has been serviced regularly & has had a new cambelt fitted within the last 5000miles but I guess unless you go to a VW dealer the intervals don't get reset?
  • Opinions я Us
« Reply #3 on: 06 October 2009, 14:40 »
Copied from another post cos I haz the pwr of SEARCH:
1) Turn ignition off
2) Hold down trip counter reset button
3) Turn ignition on
4) While still holding the reset button, turn the clock adjust knob clockwise and hold it.
5) Let go of the reset button first, then the clock adjust.
Offline popleyruss
« Reply #4 on: 07 October 2009, 19:14 »
thanks for that i was looking for the same thing
3) Turn ignition on
Just plain dubbin
« Reply #5 on: 13 October 2009, 14:00 »
I don't have a clock adjust knob, just 2 little buttons set into the plastic screen.
Offline popleyruss
« Reply #6 on: 13 October 2009, 14:21 »
Bottoms mins and tops hours as far as I no mate ill try this tonight and let u no
Just plain dubbin
Offline popleyruss
« Reply #7 on: 13 October 2009, 14:50 »
Just read what u wrote properly sorry mate ill send u a link when I get in as I'm on my phone sumone has posted it before but ill put the link up unless u post ya email adress and I can email a picture off my phone
Just plain dubbin
Offline popleyruss
« Reply #8 on: 13 October 2009, 15:58 »
 this is a post from boneybradley not more i just copied and pasted it thanks for the info from him
IN00 means you don't need a service
OEL= oil service
IN01= inspection service
IN02=major service
OEL= oil service
Switch ignition on
Press and hold left hand button on speedo display
Switch ign off
Release button
The letters "OEL" will appear on the speedo display
Press clock minute button (lower one) until "-----" is shown
Switch ign on and "IN00" should show
Ignition on
Switch ignition off
Release button
Press and release button
IN01 will show in the display
Press left hand button to show "OEL"
Press right hand button to show "-----"
Switch ignition on and "IN00" should show
IN02=Major service
Ignition on
Press and hold left hand button on dash
Switch ignition off
Release button
IN02 will show in the display
Press left hand button to show "IN01"
Repeat to reset "OEL"
PROGRAMMING THE SETTINGS OF THE VARIOUS SERVICE COUNTERS.
It is possible to program the current settings you want for the counters.
This used if the speedo display is replaced or if you want to set your intervals to a shorter value than the factory.  For example, you can set the computer to display OEL after only 3000 miles.
1. Turn on the ignition
2. Depress the trip-reset button on the speedo display
   Also depress the button to set the MINUTES of the digital clock (lower one).
3. The LCD display should read "OEL 1,S", where the S indicates SET.
4. Using the trip-reset button, you can call up the following counter banks
for the service intervals in sequence:
   OEL 1,S   - distance counter for oil change (ie 7500 miles normally)
   OEL 2,S - time counter for oil change (ie 12 months)
   IN 01,S - time counter for yearly service interval (ie 12 months)
   IN 02,S - distance counter for special service (ie 15,000 miles )
5. Using the button for setting the MINUTES on the digital clock (lower one), you can display the value of the counter. Repeated pressing of the button will select a subsequent lower value of the counter and at the lowest level, it will reset to the highest level and begin to decrease again.   The step sizes are blocks of miles (500 miles, I think) and months (the time setting for the yearly service is a bit strange as I think it can be set to 1,2,3,4,5 or 6(Maybe it counts in 2 month blocks?  Does anyone know?).
6. Once you have set each counter to the value you want, turn off the ignition.
7. Work is done.
Just plain dubbin
« Reply #9 on: 13 October 2009, 16:01 »
Nice one, bruv.
