Author Topic: Electrical questions 16v KR  (Read 1051 times)
Offline edd16v
« on: 05 October 2009, 13:36 »
Hi,
A couple of quick questions that I'm sure somebody will be able to answer Quickly.
There is a plug that goes into the distributor (I think its a 2 pin) What is this and what does it control?
What is the component on the throttle housing that has a 2 pin plug goign to it and what does this control?
Sorry if these are really obvious question!
Thanks
Edd
Offline Tubb
Re: Electrical questions 16v KR
« Reply #1 on: 05 October 2009, 19:59 »
I think the one on the throttle body is the throttle position sensor
1987 Golf GTI 16v 2.0 - 1993 Autocavan Demo Car - For Sale!
1992 Pulsar GTi-R
Offline kraM
  • It's not the speed, it's the sudden stops...
« Reply #2 on: 05 October 2009, 20:49 »
The dizzy is 3 pins, and a hall sensor, tells the ecu when to fire the coil, and where the engine is (in it's cycle, not that it is located under the bonnet...)
kraM
It's not the speed... it's the sudden stops...
Offline raferackstraw
« Reply #3 on: 07 October 2009, 13:51 »
2pin on throttle housing is throttle position sensor,
 when throttle is closed it should active the switch which should active the idle stabilisation iirc
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
