Golf mk2
Speedo
Topic: Speedo (Read 1580 times)
f101nva
Just got here
Speedo
21 September 2004, 20:56 »
Is there anyone that can help me?!
I've just bought my 2nd mk2 8v gti and on closer inspection found that the speedos don't match!
One reads up to 120 mph & the other 160mph.
Both are 1989 3dr 8v's.
I've contacted as many previous owners as poss as to an instrument swap but no one seems to know!?
Any ideas?
Dizzie
Forum addict
Make friends with your fast
Re: Speedo
22 September 2004, 12:00 »
probably just got a 16v speedo in there. Shouldn't make any difference just the needle moves slower. easy to do as the speedo gauge is completely mechanical.
Mk2 Golf GTi restoration -
https://youtu.be/s-Jj5bABxM8
Blue MK2
Guest
Re: Speedo
22 September 2004, 13:16 »
ive put some 160mph clocks in mine. The speedo still reads the same. 160mph clocks are from g60's enit?
the boy mike
Re: Speedo
23 September 2004, 22:47 »
My valver has 160mph clocks, and that's totally standard. Imagine the G60 would have a 160mph speedo as well. I're reckon the difference would be the position of the red line on the rev counter - valver will be higher..
f101nva
Just got here
Re: Speedo
27 September 2004, 15:46 »
Redline on mine starts at 6800.
Don't think i'll push it too much though, just in case.
Thanks for the info guys.
Gambit
Forum addict
Re: Speedo
27 September 2004, 16:13 »
120 mph & 160mph clocks both use the same drive in the gearbox, so are interchangeable
140mph clocks use a different drive on the gearbox end of the speedo cable, so if you change the clocks u need to change the drive
Golf mk2
Speedo
