Author Topic: error code, poss timing fault, sorry i know its well covered  (Read 5461 times)
Offline mark-mk3gti
Re: error code, poss timing fault, sorry i know its well covered
« Reply #10 on: 05 October 2009, 14:10 »
hi, cheers for reply,  i cant do it myself, ill have to get it booked in, which is annoying cos was there this morning, but i didnt know it was out of spec till after, just gets frustrating cos i dont know anyone round here that can do these sorts of things so i have to pay someone, which p1sses me off,  but still, i need to get it right before oct16th ideally, cheers for your advice..
Offline leegt5
« Reply #11 on: 05 October 2009, 17:59 »
If its timed up correctly as you say, then the fault cleared and you can rev over 5k then it comes back again with a fault and wont go over 5k then your hall sensor or dizzy is borked !! To get the hall sensor off the dizzy is long winded and its much easier to just buy another dizzy !!
I got your PM and the specification values I posted won't throw an error like vagcom is showing on yours, mine were mm adjustments to bring into the specification values. Even before I adjusted it, it would still rev over 5k and throw no errors, something is causing it to go well out of spec to throw an error in Vagcom....
Dizzy is easy to fit, the hardest part is getting to old one off as 10 years of rust around the base etc etc..
The way I did it is as followed !!
1. Remove oil breather pipe near the cam belt cover.
2. Remove Cam belt cover.
3. Remove spark plugs (Makes it easier to turn the engine to TDC)
4. Turn engine until TDC is reached using mark on camshaft and head as your TDC mark.
5. Remove dizzy cap and your rotor arm should be pointing to the mark on the edge of the dizzy.
6. Draw a line on the dizzy base and engine block to mark the position yours was in.
7. Unplug Hall sensor and remove dizzy base clamp bolt and clamp.
8. Gently tap dizzy with a hammer to lossen it free from the rust (takes a while) then remove dizzy.
9. With the new Dizzy make a mark in the same position on its base like your old one and then slot new dizzy in so the markings you made on your engine block and on the new dizzy line up. As your lowering it into position with your markings in line turn the rotor arm slightly to the right or its correct position so as it then is inserted it will then go into the correct position.
10. Once dizzy is in secure base clap with bolt and then put everything back in the reverse order.
The point I was making about mine being out of spec was I ran vagcom once the new one was on and 2 of the hall sensor measuring block values were slightly out so I undone the clamp and adjusted 1mm counter clockwise and it was then on the limit of the 2 specs so I adjusted it another 1mm and then it was bang within the middle of the 2 measuring block values see below.
Before slight adjustment
1 Co-ordination ( Specification 57 - 60 or 1.0 )  Mine reads 2.0   << Slightly Out
2 Co-ordination2 ( Specification 5 - 8 )  Mine reads 9.0  << Slightly Out
3 Altitude Correction ( Specification 0.85 - 1.15 ) Mine reads 1.12
4 Operating Conditions ( Specification 00000000 ) Mine reads 00000000
After adjustment
1 Co-ordination ( Specification 57 - 60 or 1.0 )  Mine reads 60
2 Co-ordination2 ( Specification 5 - 8 )  Mine reads 7
If you were local I'd could guide you on how to do it if your not that confident...
« Last Edit: 05 October 2009, 18:30 by leegt5 »
Offline mark-mk3gti
« Reply #12 on: 05 October 2009, 18:24 »
hi there, cheers for the info, i dont know if ill be having a go or if my dad can help me, but now i am looking for a distributor, any ideas on a cheap place? lol, am skint at the mo, like everyone else, and its a long story, so the cheaper the better.. hope to get a recon one thou, unless new ones arent much more..
thnks agin for ur help. will let u know how it goes, wish u cud come help me but i,m in manchester, so its a long way away.. :)
Offline leegt5
« Reply #13 on: 05 October 2009, 18:31 »
Got mine of Ebay for £10 + £5 postage...
Offline mark-mk3gti
« Reply #14 on: 05 October 2009, 18:39 »
good price,  ive seen a new one for 45 + postage so will prob order it tommorrow!  and need a dizzy cap aswell cos mine has def seen better days, specially where the clips are,
thanks again for ur help, its being a stressfull day, i ve being cleaning things, resetting things, lol hope it wont always be like this!   take it easy
ill let you know how it goes,
mark
btw are u going blackpool on fri? unphazed having a bit of a meet, 7.30 at bandq, drive down the lights then a pint (of coke) in a big pub
Offline leegt5
« Reply #15 on: 05 October 2009, 21:02 »
Fraid not mate got an exam next week so any time is spent revising !! Plus its a good 4 hours to blackpool from here !!
