Author Topic: Lights left on buzzer  (Read 4017 times)
Offline BC
Re: Lights left on buzzer
« Reply #10 on: 06 October 2004, 22:29 »
No, I'm not too clever with electronics.
I have a basic idea but thats it. Not a knowledge of it.
I reckon it'll be a good idea if you put a simple schematic up on the board though.
I got a link to a PDF (6kb) of a simple schematic of the kit I bought here http://www.velleman-kit.com/Downloads/0/Infosheet_K3505_off%20lights.pdf
Just wondered if I could add anything to it to finish it off
Rain
« Reply #11 on: 06 October 2004, 22:37 »
its fine to be honest but to get it working with parking and lights youll need 2 buzzers.
Offline JMallows
« Reply #12 on: 06 October 2004, 22:41 »
What about a similar approach to mine:  One wire from door switch to buzzer, and the other side of the buzzer goes into the boot, and then splits and goes to both of the taillights. There are spade terminals on the light units to attach wires.... That has to be a simple and very effective way!?
A clever person solves a problem. A wise person avoids it.
Rain
« Reply #13 on: 06 October 2004, 22:44 »
cant split it to both lights without diodes or it means that the other light will get power cause of the connection.
Offline JMallows
« Reply #14 on: 06 October 2004, 22:47 »
Yeah, but that doesn't matter, cos it'll remind you all the same!
Rain
« Reply #15 on: 06 October 2004, 22:50 »
yer fair point, if you can solder though use the rear of the fuse box saves running to the rear.
Offline JMallows
« Reply #16 on: 06 October 2004, 23:00 »
Definatley, but i was hoping to give everyone a simple guide, and running it to the rear takes about 5 minutes at the most! It does cost a bit more though, unless you have a lot of wire! All you need to do is remove the kick plate. I ran two wires to the boot so i could have a switch in the dash for my split relay, in the boot.
Offline BC
« Reply #17 on: 06 October 2004, 23:32 »
You can get to all the wires you need for it, by taking off the blank/false switch above the Dip/Headllight switch. (Pull firmly)
Then press your finger on the metal spring clip on the top of the Dip/Headlight switch unit, to push the top out first. ?Then put your finger in a bit more to get just behind the Dip/Headlight unit to get the bottom part out. ?Pull the unit out a few inches for access to the wires.
I think I'll get another kit. ?Easier. Haha.
Thanks for your help guys
Now I can get on with my next trick. ?A motorised sunroof. LOL
Offline JMallows
« Reply #18 on: 07 October 2004, 00:56 »
Theres a MUCH easier way to get to the switch! Put it in the on position, then lever it out from the bottom! With a screwdriver in the litle slot, that was made for removing the switches!!!!! Then you can remove the plug and do it properly!
