Author Topic: reverse camera - change headunit?  (Read 3169 times)
Offline p3eps
« on: 01 October 2009, 18:37 »
Hopefully I'll be ordering soon, and I fancy the reverse camera on my options list!
I have my own RNS-510 to retrofit when I get the car... so I'm assuming I'm going to have to spec a RCD-510 to be able to get the reverse camera as an option?
Not really a problem, as it'll cost about £300 extra, but I should be able to get most of this back if I sell it on eBay.
Now the question...
Is the RNS-510 a direct swap for the RCD-510 with the reverse camera?   I'm hoping that any wires and connectors will be on the camera side and it'll just be a plug and play exercise.  I realise I'll probably have to VagCom the RNS to get it fully working with the MFD, but I don't mind buying one with the amount of money I'll save by retrofitting the RNS and Bluetooth.
Has anyone done this?!
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline mac7
Golf R
Offline p3eps
Re: reverse camera - change headunit?
« Reply #2 on: 01 October 2009, 19:12 »
Thanks for the reply...
I've been through all the links on the page you've posted, and I've been there before!
It still doesn't tell me if I can do a straight swap from an RCD to an RNS with the reverse camera.  It only tells me how to retro fit a camera to an RNS!
Offline mac7
« Reply #3 on: 01 October 2009, 20:45 »
Well, if a retro-fitted camera works with an RNS510, an RNS510 will work with a camera...
the guy on R32OC doesn't mention needing to re-code the RNS, it worked first time.
Golf R
Offline cameluk
« Reply #4 on: 03 October 2009, 01:29 »
Pretty much a straight job, you will have to recode the rns for a mkvi ( bap) and for the camera
Offline p3eps
« Reply #5 on: 03 October 2009, 09:11 »
I'm going to ask the dealer if they can recode it before I pick the car up - and also enable bluetooth (for a retrofit too).
If not, I'll buy a vagcom!
