Author Topic: F**king rattle!  (Read 1876 times)
Offline Sam
  • Sam I am
F**king rattle!
« on: 01 October 2009, 17:10 »
I have a rattle from under my engine bay, i have put draft proof tape on everthing that could posibly move (just like numberplate pads) and its still there at about 3200 revs! Any ideas????????? :angry:
Offline JimR
Re: F**king rattle!
« Reply #1 on: 01 October 2009, 17:47 »
Exhaust manifold heat shield? Could be any number of things? If it does it at standstill when revving the engine then the obvious thing to do is lift the lid and listen around while giving it some throttle.
Mk2 GTi.
Offline Sam
  • Sam I am
Re: F**king rattle!
« Reply #2 on: 01 October 2009, 18:05 »
Yer i have tried doing that and it seems to be purely a driving along thing. I will have it on the ramps on saturday anyhow for an oil leak so i will ask the mech to check for anything
Offline laurenceyon
Re: F**king rattle!
« Reply #3 on: 01 October 2009, 20:18 »
I had this problem - turned out to be the bolt that secured the water pump was lose! If you rev you engine and watch the bolt/pump you can tell whether it's rattleing or not.
I know your pain man, the noise almost drove me insane as it only started at 2/3rpm. Oh and mine is a 16 Valve, I hope this helps  :smiley:
Hi my name is Laurence, I'm very much like you. Only better.
Offline Horney
Re: F**king rattle!
« Reply #4 on: 01 October 2009, 20:32 »
I can't hear anything over my exhaust, ha ha!
nick
Offline JC
  • Back in the North.
Re: F**king rattle!
« Reply #5 on: 01 October 2009, 21:22 »
bottom bolt on alternator, had bottomed out on the threads, not the mounts, rattletastic  :grin:
Offline Dan34
  • VTEC Powerzzzz
Re: F**king rattle!
« Reply #6 on: 02 October 2009, 15:38 »
What exhaust have you got? Ive got a mate who has a stainless one on (cant remember make) and the baffles have started to go in it and make a rattle sort of noise at a certain revs.
Dan
Offline ianmaxtec
Re: F**king rattle!
« Reply #7 on: 02 October 2009, 22:11 »
had the same problem, it turned out to be the exhaust  heat shield which runs over the exhaust to the rear. The metal is very soft and can easily be bent out of shape and come in contact with the underside of the car, it was a bit fiddley to fix
Offline dan_apps
  • too low for british roads!
Re: F**king rattle!
« Reply #8 on: 02 October 2009, 22:17 »
+1 heat shield just clips onto pipework and rattles like a twit when loose!
Offline Sam
  • Sam I am
Re: F**king rattle!
« Reply #9 on: 03 October 2009, 13:43 »
yer i dicked about with the heatshield and it got a wee bit better then went back to normal, i found a loose piece of metal as well running down the front of the rad, will try tightening this too.... :angry:
