Author Topic: Oil Change  (Read 4123 times)
Offline Das Auto
Oil Change
« on: 01 October 2009, 11:03 »
After the first 1000 miles does this come up on the MFD or is it something we do because it is reccomended also who has had there oil flushed out and changed after 1000 miles to get rid of all the sh**e
Offline Das Auto
Re: Oil Change
« Reply #1 on: 01 October 2009, 14:54 »
bump
Offline howlingmoon
Re: Oil Change
« Reply #2 on: 01 October 2009, 15:03 »
I dont think you need to change oil after 1k km... You can see when you need to do your next service using your MFD... :cool:
GTI Mk6 United Grey, 18" Monza Shadows, RNS310, Executive Package, ACC
Offline Das Auto
Re: Oil Change
« Reply #3 on: 01 October 2009, 15:38 »
I thought it should be done after 1000 miles to get rid of all the metal fragments from the running in period ???
Offline mac7
Re: Oil Change
« Reply #4 on: 01 October 2009, 17:40 »
I'm not sure whether they still do this - the MFD will tell you if they do.
Like running in, many people will tell you you don't need to do this with modern engines.
If you're going to keep the car for 100,000 miles then it would be a good idea IMO. If you are going to trade it in after a few years, it'll almost certainly make no difference to you.
Personally, I'd do it anyway at around the 1500 mile mark - a few litres of oil and a filter isn't a huge cost after all. But don't 'flush' the engine - just drain it. Flushing can do more harm than good.
« Last Edit: 01 October 2009, 17:41 by mac7 »
Golf R
Offline simonpolly
Re: Oil Change
« Reply #5 on: 01 October 2009, 18:45 »
No oil change needed at 1000 miles
Golfgti build quality is average at best.
Offline keelaw
  • It's here!
Re: Oil Change
« Reply #6 on: 03 October 2009, 11:22 »
seriously?!?!   :huh:  :embarassed:  :sick:
Mk6 Golf GTI 5dr, DBP, Monza Shadow, Xenons, ACC, RCD510, Park Assist, Camera, Lux pack.... and now bluetooth.... and now DSG!
Offline Fred_du_94
Re: Oil Change
« Reply #7 on: 03 October 2009, 11:33 »
Well, I have not read anywhere it was needed.
For sure if VW could snatch some extra bucks, they would certainly have mentioned it the manual !
Offline DWGTI
  • 1996 GTI 16V
Re: Oil Change
« Reply #8 on: 09 October 2009, 20:09 »
Im with you on this one. Im no mechanic but the "running in" period must have an adverse effect on the oil. Its a cheap fix to change it and the filter just for the peace of mind. Changing the oil cant cause any harm or can it??
Offline mac7
Re: Oil Change
« Reply #9 on: 09 October 2009, 20:27 »
Back in the day of the Mk2 Golf VW used to use a higher capacity oil filter out of the factory to prevent possible build up of metallic wear debris and other contaminants reducing flow. I believe synthetic oils, modern filter design and closer control of manufacturing tolerances mean this is not entirely necessary. I'm old-school when it comes to this sort of thing so I'd rather spend £40 on some oil and a filter and do an early change at 1500 miles.
Golf R
