Author Topic: Rear Bearings - Rears Converted  (Read 832 times)
Offline gavL
« on: 01 October 2009, 09:57 »
Supposedly the rear breaks on my Mk2 where converted as the documents say to Mk3/Mk4. From what the previous owner said she had a full set of G60's put on the front, but the rears are from a A3?
Can anyone shed any light on it?
| DubNorthEast |
Re: Rear Bearings - Rears Converted
« Reply #1 on: 01 October 2009, 10:44 »
quite a few models across the VAG range use a similar style of caliper to the MK2. if they're alloy they're MK4 type, if not they're MK2/3 type.  if theres a massive spring on the handbrake mech they're mk2, but if from audi a3 they're more likely to be MK3/MK4 stylee.
edit: there is also a conversion you can do using late SEAT/Polo parts, to the later type of rears that use a seperate hub & bearing rather than a rear disc with a built in bearing.  Pics with the wheel off will help :)
« Last Edit: 01 October 2009, 10:46 by rubjonny »
Offline gavL
« Reply #2 on: 01 October 2009, 15:51 »
Will take a photo tomorrow in the morning and post it up :) Cheers for the help :)
| DubNorthEast |
Offline Mew
« Reply #3 on: 01 October 2009, 17:38 »
Isn't your car running a 5 stud setup?
Offline gavL
« Reply #4 on: 20 November 2009, 12:59 »
Nope not a 5 stud conversion.
Going to get a photo for this ASAP. As it's the last job to do now on the Golf and it will be back to its glory :)
| DubNorthEast |
