Author Topic: Car won't start...ECU?  (Read 4760 times)
Offline skcollob_ho
Re: Car won't start...ECU?
« Reply #20 on: 02 October 2009, 15:20 »
But would the crank sensor produce the same symptom as the imobiliser, where the engine turns ans starts on full throttle, but dies within a couple of seconds?
A totalitarian regime, crushes all autonomy in it's drive to seize the human soul.
Offline axewielder
  • 95 dragon 8v
« Reply #21 on: 02 October 2009, 15:26 »
quite possibly, the one i have on atm has some bare wires+ when i drive in the wet it dies, then wil start for a few secs with full throttle+ then die again until it dries out
adamrob69
« Reply #22 on: 02 October 2009, 18:15 »
yes, if it is a stock imobilser that is causing the problem then it is built into the ECU. Check first and make sure you dont have an aftermarket ECU.
I believe the imobiliser in the ECU can be bypassed, but i carnt remember how and it requires special software.
Have you checked the igniton switch. I carnt remember the wiring for it, but it 'probably' has a wire that feeds the immobilser.
The revision number on the end of the part number is a revision number and shouldnt cause a problem. If you want to double check look up the part number and revision and double check, but in the past i have had ECUs where the revision is alot newer and now problems. If you change the ECU, its probable that it will need coding to your keys. £60 at VW main dealers or find some kind person that has the right software to do it
Offline skcollob_ho
« Reply #23 on: 02 October 2009, 18:33 »
After a bit more digging, and for the benefit of anyone that finds this thread through searching, I have found the following.
ECU P/N: 037 906 024 ** [where you will find the following letters]
The following are imobilised;
AE, AL, BE, BF.
Without imobiliser are;
F, G, AB.
This is probably a stupid question, but I may have located an ECU out of a Seat Toledo that carries the AB revision. Will i be able to transplant this into my valver without issue? If I'm getting it right, then the AB revision doesn't have an imobiliser, thus no transponder, thus no need for the key to be re-programmed?
« Last Edit: 02 October 2009, 18:38 by skcollob_ho »
Offline axewielder
  • 95 dragon 8v
« Reply #24 on: 02 October 2009, 18:43 »
ecu for ABF part no 037 997 024 GX  other revisions G, X, AE, DX, BE,
Same part no but BX/SX is the 2E(old 8v) ecu so i doubt they are compatible
Offline axewielder
  • 95 dragon 8v
« Reply #25 on: 02 October 2009, 18:44 »
lol, should be fine outta seat, where did you get the info about immo or not??
Offline Khare
  • The bear that khares
« Reply #26 on: 02 October 2009, 18:48 »
i believe the immob is located in the clocks, not in the ECU itself.
Offline skcollob_ho
« Reply #27 on: 02 October 2009, 18:49 »
i think you're talking about the transponder thats located behind the clocks.
Offline skcollob_ho
« Reply #28 on: 02 October 2009, 18:50 »
I was googling! Here's the link...
http://forums.vwvortex.com/zerothread?id=3713684&postid=46359025
Offline Khare
« Reply #29 on: 02 October 2009, 18:54 »
no the transponder itself is in the key, the immob is part of the clocks.
