Author Topic: BBS RX2 (II) Info  (Read 2461 times)
Offline funkyfive
BBS RX2 (II) Info
« on: 29 September 2009, 15:30 »
I am just about to invest in a new set of RIMs.
I've been told they are off a Mk4 and are there any issues with them on a Mk3 eg. spacers, caliper rubbing etc..?
What is the difference between the Mk3 and Mk4 BBS RX2 Rims?
Offline shepgti
Re: BBS RX2 (II) Info
« Reply #1 on: 29 September 2009, 15:55 »
only differnce is mk3 anni rims were 7j wereas the mk4 anni's were 6.5j no issues in fitting either
« Reply #2 on: 29 September 2009, 16:13 »
If they are from a mk4 the tyres will be too big.
Offline funkyfive
« Reply #3 on: 29 September 2009, 16:34 »
Tyres are 195/45/16 V
Offline funkyfive
« Reply #4 on: 29 September 2009, 16:48 »
Does anyone know if the offset is different to my current standard GTI alloys?
Offline shepgti
« Reply #5 on: 29 September 2009, 17:28 »
195/45/16 is correct tyre size, offset is 43 which is the same as standard longbeach alloys http://boneybradley.webs.com/thewheels.htm
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 29 September 2009, 18:22 »
the only issue you could have is the rear bearing covers and fitting the center caps as they stick out a few more mm on the mk3...some people run without (not recommended) or slightly flatten them (press the dome in a bit with a small hammer)
nick_thomas
« Reply #7 on: 29 September 2009, 20:04 »
Bradley you're wrong. I had no issues with the bearing caps.
« Reply #8 on: 29 September 2009, 20:05 »
Just run 3mm spacers.
nick_thomas
« Reply #9 on: 29 September 2009, 20:06 »
The need for spacers will be purely aesthetic, there is no fouling whatsoever.
