Author Topic: any difference in 8v and 16v fuel pump??  (Read 6675 times)
Offline Gareth
« on: 28 September 2009, 22:29 »
hi all ive got a 16v kr engine i got cheap with wiring loom ecu and gear box and ive put it in my 1.6 driver! ive got an 8v gti fuel pump kicking about and wondered if that would work with the 16v gti engine or is there in difference in wiring? cheers
Re: any difference in 8v and 16v fuel pump??
« Reply #1 on: 28 September 2009, 23:26 »
Pump is different from memory.
Offline gstar-dubworld
  • Here comes the piano man - his a peaceful man..
« Reply #2 on: 29 September 2009, 00:45 »
Fuel pressure...
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #3 on: 29 September 2009, 07:54 »
yep you need the 16v one pressure req is about twice that of the 8v unit
VeeDubGTI16v
« Reply #4 on: 29 September 2009, 08:56 »
it will work if its a kjet 8v pump
Offline Ben Lessani
« Reply #5 on: 29 September 2009, 13:41 »
K-Jet 8v and 16v pumps are the same and match the pressure of the 16v ABF pump IIRC
Digi 8v pump is weaker than the K-Jet 8/16v pump
VeeDubGTI16v
« Reply #6 on: 29 September 2009, 13:54 »
wont the abf pump be the same as digifant? its only the kjets that need higher fuel pressure i believe
Offline Ben Lessani
« Reply #7 on: 29 September 2009, 13:58 »
AFAIK you can't run an ABF off a standard Digi 8v pump - it doesn't have enough flow ... RJ/DP/DH/DPB will correct me I'm sure ;)
« Reply #8 on: 29 September 2009, 15:36 »
MK2 digi pump will run an ABF fine :)
MK3 GTI 8v/16v pump is rated for 3bar, not sure about the digi but I'm pretty sure its also 3bar.  if i can get the bosch number off one I can find out.
edit: digi mk2 pump specs:
0 580 453 914 - 3bar - 75 L/HR
edit2: actually I just remembered the early SEAT Toledo ABF used the same pump as the MK2 digi, so it definitly will work :)
« Last Edit: 29 September 2009, 15:53 by rubjonny »
Offline Gareth
« Reply #9 on: 29 September 2009, 15:36 »
ok thanks for all the info :)
