Author Topic: Mk2 1.8 8v PB engine overheating  (Read 1105 times)
Offline mk2 virus
« on: 28 September 2009, 21:10 »
Hi Guys
Im having a problem with my engine, when started from cold and left to idle a bit it idles fine for about 10 minutes, temperature needle moving up slowly and just before it hits centre steam starts pouring from the expansion tank and then the light starts to flash. Any ideas what could be causing this or how to solve it?
Thanks
Offline weazgti
Re: Mk2 1.8 8v PB engine overheating
« Reply #1 on: 28 September 2009, 22:15 »
Check the o ring in the cap, if water gets past it water comes out a little hole in the side of the expansion tank (a pin hole  in a square bit near the bracket which holds it on)
Ihad this few weeks ago and luckily my neighbour had a vento which he lent me the cap off,then i just pushed the seal back in mine.
If you pour water down the edge of where the cap goes,sort of down the side of the thread youll see water come out.
Think a lot of people replace these for the later blue caps.
« Last Edit: 28 September 2009, 22:24 by weazgti »
Offline Agreeable Slick
  • Unit
« Reply #2 on: 28 September 2009, 22:28 »
