Author Topic: Annoying Rattle/Banging!  (Read 2448 times)
Offline Len
« on: 28 September 2009, 11:04 »
Its annoying because it happens ONLY at a certain time!
That is coming off a motorway where you have those yellow painted humps/lines on the slip road and this happens when you get towards the end of those as you slow down.
At first I thought it was the bonnet stay. No!
Then the exhaust banging. No!  (after fitting new mounts)
So I'm kinda stumped. Definitely sounds like something loose and banging against something.
Anybody else ever have this?
www.sas.org.uk
www.the-ace.org.uk
Re: Annoying Rattle/Banging!
« Reply #1 on: 28 September 2009, 11:06 »
If it helps, on mine it was the top mounts.
Offline Len
« Reply #2 on: 28 September 2009, 11:11 »
Cant believe its them.
1. They are rubber and its definitely a metallic sound.
2. They should be fine as were renewed when I did the suspension.
www.sas.org.uk
www.the-ace.org.uk
« Reply #3 on: 28 September 2009, 11:19 »
It was the bearing on mine that was rattling and not the rubber.
Offline howie_669
« Reply #4 on: 28 September 2009, 11:28 »
I take it you are struggling to even locate the area of th noise as you have thought it was the bonnet or the exhaust so must be quite loud then.  I get a slight noise over the those bumbs but it seems to coem fro mthe rear suspension.
« Reply #5 on: 28 September 2009, 11:42 »
Also worth checking you rear top mounts, if the rubber is soft then the shock will rattle.
Offline mumbles
« Reply #6 on: 28 September 2009, 12:29 »
could it be something like a loose heat shield??
Wouldn't be fun if it was easy, but does it have to be this much fun?
Audi A4 Sport
Offline wee-golfer
« Reply #7 on: 28 September 2009, 12:29 »
got the same mate, my clips that hold the heatshield r coming away and makes the noise of an empty tin of beans rattling around underneath the car
Offline Len
« Reply #8 on: 28 September 2009, 12:43 »
New ones fitted with suspension! I dont do jobs by half!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #9 on: 28 September 2009, 12:45 »
Yep! Totally baffled, hence asking on here!
Sounds like engine bay and not from rear.
www.sas.org.uk
www.the-ace.org.uk
