Author Topic: Worn star bolt on standard alloy wheel security cap  (Read 1953 times)
Offline meljames24
« on: 27 September 2009, 17:34 »
Hi all, any advice on getting my wheel off? The star bolt which secures the cap seems to have had its tines worn off just a little too much to get enough grip with the key.
Its had a pint of WD and Ive hammered the key in before turning to try and get some purchase, but no luck yet. I've had two heavy handed suggestions: 1) Chisel a slot in the bolt so a flat key can be used 2) drill the bolt out.
I'd rather try some more subtle things first, so any ideas?
Ta,
Mel.
Offline richard s
Re: Worn star bolt on standard alloy wheel security cap
« Reply #1 on: 27 September 2009, 18:08 »
have a look in machine mart im sure they do a tool that is for removing wheel locknuts
« Reply #2 on: 28 September 2009, 09:54 »
i believe he means the wee bolt that holds the centre cap on. if so you dont have much choice but to drill it out, could try a larger spline bit tapped in with a hammer
Offline meljames24
« Reply #3 on: 28 September 2009, 15:13 »
Thanks for that, I thought drilling might be the only option. And just to correct you, I'm a actually a she.
Melanie
« Reply #4 on: 28 September 2009, 16:15 »
ah sorry about that!
bit dagerous to declare you are a female mk2 owner on vw forums :grin:
Offline Neo Badness
  • Feet are for pedals
« Reply #5 on: 28 September 2009, 20:59 »
 :grin:
Yup, better keep your nerd repellent at the ready...
You could try using a dremmel to put a groove in the bolt to allow a flat bladed screwdriver to be used. Bit kinder than a chisel/large persuading stick... :wink: failing that I'd just drill it out and replace the bolt
Offline Ben Lessani
« Reply #6 on: 29 September 2009, 13:48 »
.... * is waiting to see how long it is before someone asks for pics * :rolleyes:
