Author Topic: bearing dust caps  (Read 1898 times)
Offline bluquarta
bearing dust caps
« on: 27 September 2009, 14:11 »
just noticed that my n/s rear centre cap wont stay on properly cos the bearing dust cap is a bit battered. can I get away with hammering it flat a bit whilst the wheel is on or will this damage the bearings inside? should I take the wheel off and have a go at the dust cap separately?
Offline VR6-Joe
Re: bearing dust caps
« Reply #1 on: 27 September 2009, 14:16 »
Hammering it flat shouldn't cause any damage. Better to take the wheel off to allow more access to the cap and not damage your wheels.
My dad has removed his dust covers completely on his VR6 to be able to fit Audi TT wheels. It's been like it for quite some time and he hasn't had any problems :)
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
VW BUSH
« Reply #2 on: 27 September 2009, 15:01 »
Water and dirt in the grease will fcuk them pretty quickly also as grease gets hot and runny it will run away from the bearing causing it to fail
I would modify it wtih a hammer to make it fit it just needs to be water tight and hold grease :smiley:
Offline VR6-Joe
« Reply #3 on: 27 September 2009, 16:16 »
How will water and dirt get in there when there's an alloy wheel and a centre cap covering it up? :huh:
And it's easily been like it for a year now with no problems.
« Reply #4 on: 27 September 2009, 16:31 »
+1 it is better to run them.
VW BUSH
« Reply #5 on: 27 September 2009, 16:36 »
As the air space cools it will draw in moisture wheel/cap is not air or water tight.
 :smiley:
Offline AudiA8Quattro
« Reply #6 on: 27 September 2009, 18:32 »
The bearings won't last as long without the caps.
Offline bluquarta
« Reply #7 on: 28 September 2009, 09:39 »
on further inspection, i think it was more a case of the dust cap not fitting properly. have secured it a bit better and that will have to do for now. the bearing prob needs replacing as its had an advisory for play and been adjusted already, so i'll add it to the 'to do' list! ta for the replies
Offline bpeterson
« Reply #8 on: 13 January 2011, 01:49 »
Has anyone actually ever had the omix dust cap get stuck there? I want to take the cap off so that I can pump some air in since the tyre pressure seems awefully low, but I haven't been able to get it off in 4 days. I did the air about a couple of months ago, so dunno why it ain't coming off. Anything from your vast experiences that can help me?
