Author Topic: URGENT ECU HELP! ADY ECU - UPDATE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  (Read 8167 times)
Offline Khare
  • The bear that khares
Re: URGENT ECU HELP! ADY ECU - UPDATE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #40 on: 29 September 2009, 13:31 »
Just spoke to topher, and he confirmed its the immob. Also, checked key, and it does have the chip. He says I need vag tacho to find the pin# then vagcom to decode it. See here  :smiley:
Offline Len
« Reply #41 on: 29 September 2009, 13:37 »
Good luck! Hope ya get it fixed by Saturday!
www.sas.org.uk
www.the-ace.org.uk
Offline Khare
« Reply #42 on: 29 September 2009, 13:41 »
Topher said that if JKM finish up early enough on Saturday then he will try and pop over and carry out the procedure, but I'm gonna try and find someone else with vag tacho to save topher a long journey. So if anyone has vag tacho in bournemouth area, could they please PM me!
Offline axewielder
  • 95 dragon 8v
« Reply #43 on: 29 September 2009, 13:42 »
ive got a version of tacho but havent used it/ know if it works+ if i need another cable? i have fully working vagcom but dont know if thats enough?
Offline JC
  • Back in the North.
« Reply #44 on: 29 September 2009, 13:49 »
oh dear  :lipsrsealed:
Offline Len
« Reply #45 on: 29 September 2009, 13:51 »
axewielder/topher talk = possible solution
www.sas.org.uk
www.the-ace.org.uk
Offline Khare
« Reply #46 on: 29 September 2009, 13:54 »
Not sure if anything else is needed. Do you know your way round vagcom/vag tacho?
Offline axewielder
  • 95 dragon 8v
« Reply #47 on: 29 September 2009, 14:00 »
http://www.ross-tech.com/vag-com/cars/key-matching.html
does this mean you can get the code off of vw+ just use vagcom?
i think you need the proper cable for vagtacho to work, according to mkiv forum
Offline topher
  • Administrator
  • fully functioning
« Reply #48 on: 29 September 2009, 14:20 »
i love phone calls like that
him: "hi its andres i have a problem with an ecu in my mk3"
me: "is that that tosser off the forum?"
Offline axewielder
  • 95 dragon 8v
« Reply #49 on: 29 September 2009, 14:30 »
so soes anyone know if we can get the SKC off of vw dealer so that you only need vagcom?
