Author Topic: URGENT ECU HELP! ADY ECU - UPDATE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  (Read 8209 times)
Offline Khare
  • The bear that khares
Re: URGENT ECU HELP! ADY ECU - UPDATE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #30 on: 29 September 2009, 12:38 »
Only thing I got is ECU. The immobilizer I have on at the moment turns off OK. Inside of my key is just a light, no chip or anything.
Offline axewielder
  • 95 dragon 8v
« Reply #31 on: 29 September 2009, 12:46 »
possitive there is no chip, it just looks like i small plastic rectangle, my 95 ady has one, could well be tha problem
« Reply #32 on: 29 September 2009, 12:50 »
+1 It will not stop it starting but cuts in after so could well be your problem.
« Last Edit: 29 September 2009, 12:54 by Wayne »
Offline Khare
« Reply #33 on: 29 September 2009, 12:53 »
inside my key there is nothing, just battery, a light, and the mental for the contacts. I have a seperate fob for the immob, which turns off correctly.
To decode it, what do I need? just the ECU? Cos I haven't recieved anything else.
« Reply #34 on: 29 September 2009, 13:02 »
Sounds like the new ecu is coded, I believe it can be sorted with vagcom.
Offline Khare
« Reply #35 on: 29 September 2009, 13:03 »
with vagcom?????? Excellent, Adam has vagcom. I'll give him a ring.
Offline axewielder
  • 95 dragon 8v
« Reply #36 on: 29 September 2009, 13:06 »
chip is grey rectangle top left
other wise i think vagcom will pair key to ecu or u might need vagtacho or summint?
Offline Khare
« Reply #37 on: 29 September 2009, 13:08 »
My key ain't got that.
Offline boneybradley
  • Back in a Mk3...
« Reply #38 on: 29 September 2009, 13:11 »
f.y.i all ady onward cars had a coded key (mine was one of the first built and had this) but the immobiliser will let the car start and then will cut out...post a pic of your key khare
speak to topher as he's a vag-com/key code wizz  :wink:
Offline Len
« Reply #39 on: 29 September 2009, 13:12 »
I agree! Its the immobiliser!
www.sas.org.uk
www.the-ace.org.uk
