Author Topic: noisy oil light  (Read 1247 times)
Offline vixteris
noisy oil light
« on: 18 September 2004, 16:17 »
my oil light actually makes a serious amount of noise (buzzing).  i know i have electrical problems at the moment but ive done an oil change and its still going crazy.   were they ment to make this noise for a reason at all??  just never known a car to be so goddam loud  :o
Offline mk1
Re: noisy oil light
« Reply #1 on: 18 September 2004, 18:33 »
Hi, there are two oil pressure switches on the engine and if either of the switches goes faulty it should operate the light and buzzer. If you have checked the oil pressure with a guage and it is within specs, go for the switches. One of the switches is normaly open contacts and the other is normally closed. To test these I use 2 test lamps, one end of each connected to battery positive and the other end of the test lamp to each switch, then with engine stood one lamp should be lit, and when you start the engine it should go out and the other should light. Watch for either of them flickering or not changing over. If you do replace the switches, make sure that you put the correct switch in the correct location. I have also seen some cars with the strainer on the oil pick up pipe blocked, this causes the oil pressure to drop as the engine revs are increased, drop the sump off and clean out.
Steve.
Offline vixteris
Re: noisy oil light
« Reply #2 on: 18 September 2004, 18:44 »
I havent checked the pressure yet so ill do that, i dont have a gauge wired up so ill have to do that (should have done this ages ago  ::)).
  i didnt know cars had buzzers at all, im quite impressed with the mega loud warning.  thanks for your help mark1 ill get it sorted  ;) :)
Offline vaughn
  • now team wagon, and team grumpy trainee
Re: noisy oil light
« Reply #3 on: 20 September 2004, 18:41 »
sounds like low oil pressure to me vix :(
57 plate black 5dr ed30, 1969 bay window devon camper. thats all for now folks, hopefully picking up a wagon tomoz
Offline gee
Re: noisy oil light
« Reply #4 on: 06 October 2004, 11:34 »
I have the same problem, minus the buzzer thank god! Saying that it has come on a couple of times and is annoying! I have no idea where these switches are, and what the filter thing is thats been mentioned... I'm a bit "blonde" when it comes to engines. Anyone able to explain more or got pics etc? Is it easy to do as I don't mind getting my hands dirty.
Happiness is a good health and a bad memory.
