Author Topic: JonL's 8v budget track toy - now going to be a race car! ;-)  (Read 90219 times)
Offline JonLeeper
Re: New Member and another 8v budget track toy project
« Reply #120 on: 19 October 2009, 15:59 »
I guess! ;)  Still does anyone know if I can use the Mk3 item?
Offline JonLeeper
« Reply #121 on: 19 October 2009, 16:12 »
WOW!!!  Just priced up the poly bushes fromt he Polybush site £153.86 for the front suspension and then an additional £36.56 for the sub-frame mounts and a further £25.18 of you want to do the steering rack.  That's £215.60 to fully poly bush the front.  Any one know if there is a cheaper option or anywhere that does a "kit" or "pack" option?
Offline Horney
« Reply #122 on: 19 October 2009, 16:15 »
Pretty sure the GSF Bug Pack is about £60 although that doesn't include the rack or subframe bushes.
nick
Offline Mew
« Reply #123 on: 19 October 2009, 16:40 »
just a pointer if you buy from gsf; if you go and collect you can get your 10% club gti discount ;)
Offline Horney
« Reply #124 on: 19 October 2009, 16:43 »
Depends. My local one (Reading) has really clamped down on this and will not give discount without an in date membership card or trade card. Jon is forces though so he should be able to get a discount from showing his forces card. I know this certainly works in Halfords.
nick
Offline JonLeeper
« Reply #125 on: 19 October 2009, 16:50 »
nick
Really!  I didn't know that.  Would have saved me a fair bit on tools recently.
Offline JonLeeper
« Reply #126 on: 19 October 2009, 21:49 »
I thought that I would put up a list of parts I think I need and my planned supplier.  If anyone has a better idea for a bit or knows of a better place to buy then please let me know.
Things I need to buy:
Ball joints - VW Spares
Front suspension bush set poly (?) – GSF?
Track rod joints - VW Spares
Wheel bearings - VW Spares
CV Joints complete - will give E-bay a chance (but am keeping the old ones clean and safe just in case)
256mm Discs - ?
Mintex 1155 Pads (the most recommended on here) - ?
Braded brake lines - ?
Track rods - VW Spares
G60 front strut top mounts - VW Spares
Strut nut & bolts - VW Spares
Wishbone bolts - VW Spares
Optional purchases:
Harness bar – Purpose made
Seat mountings - ?
Harnesses - ?
Current total £121.73
Offline JonLeeper
« Reply #127 on: 20 October 2009, 11:12 »
In order to keep me on track, pun intended, and assist in my planning I thought that I would creat a list of jobs that need doing.  I will then be able to tick them off as they are completed and keep an eye on where I am.  It also gives everyone else a chance to comment on my progress and point out anything that I have forgotten!
So jobs that need to be done:
Clean Wishbones 19/10/09
Paint wishbones
Fit new ball joints
Fit new bushes
Initial clean of Hubs 19/10/09
Shot blast hubs
Paint hubs
Fit new wheel bearings
Strip, clean and inspect Driveshafts and CV joints
Fit new CV joints
Re-assemble driveshafts and fit new boots
Clean and inspect ARB
Clean calliper carriers - 19/10/09
Paint calliper carriers
Clean and inspect Callipers - 19/10/09
Shot blast callipers
Service, if necessary
Paint callipers
Assemble hubs complete
Clean track rod ends - New track ends ordered
Paint track rod ends - New track rod ends ordered
Fit new track rod end joints
Strip front suspension off the Golf
Re-fit Passat suspension to Golf
Fit braided brake hoses
Renew brake fluid and bleed system
Full 4-wheel alignment and set-up
Check all engine hoses and renew as necessary
Flush radiator and refill with coolant – at increased strength
Change oil filter
Renew oil
Tune engine (Rub you may get a call here! ;))
Fit new wing mirrors, current ones fold up at any speed!
Complete plastic door cards and fit
Fill with Super
Enjoy!
Optional jobs – times money permitting:
Fit new front seats – see above post for options
Design and manufacture harness bar and fit
Fit harnesses
Offline JonLeeper
« Reply #128 on: 22 October 2009, 11:33 »
CV Joints complete - E Bay (but am keeping the old ones clean and safe just in case)
256mm Discs - ?
Calliper service kit - Big Red
Lower front strut Brace (4 point) - OMP
Track day Helmet - OMP
Optional purchases:
Seat mountings - ?
Harnesses - ?
Current total £121.73 (VW Spares)
Current Total £365.73
VW Spares - £121.73
OMP - £146.30
E-bay - £77.95
Big Red - £19.75
All prices include VAT & postage
« Last Edit: 22 October 2009, 12:03 by JonLeeper »
Offline JonLeeper
« Reply #129 on: 23 October 2009, 12:07 »
Well this will be my last update for a little bit as I have to go on holiday for a week with the family tomorrow and then am away for a four day course, courtesy of work!
I have received a couple of parcels recently, it has been like Christmas in my garage, including the suspension sent by oldmiller8, many thanks, the first lot of parts from VWSpares and this morning 4 CV Joints complete with boots.  Lots of nice shiny new stuff to go on the car!  I have also cleaned up all of the bits I took off the Passat and they have been inspected and will be serviced, painted and rebuilt when I get back into the garage.
Last night I finally managed to get the suspension changed over and packaged up my old stuff and sent back to oldmiller8.  Getting the springs and dampers off the car was easy, getting the strut tops and spring plates off the dampers was very, very hard!  I don’t know how anyone else has managed to get that bl00dy collar off but I struggled big time.  It was not until I went round to a mate’s house and we manufactured a special tool from some 14mm Internal Diameter steel bar that we actually succeeded.  I now have a new tool but the effort was exceptional for what should be a simple job.  The other big downer was that the rear spring plates were very tatty.  One had actually rusted all the way through and the spring was pushing put of the top!  We turned the springplate round when we refitted but I have had to order new anyway.  Failure of any suspension part out on a track is not an option I want, especially if I know about it in advance.  I have now ordered now springplates, boots and mountings for the rear so they will go on once they arrive.
I still need to sort out seating as I cannot find any Corrado seats in the vicinity but I may have a new cunning plan!  The mate I saw last night races and is currently building a MX5 car and has placed a very large order with a custom cage manufacturer.  He has kindly offered to ask for a 2m length of FIA approved roll cage bar that we will cut to length and tack onto some 8mm steel plate to make a harness bar that sits between the rear seatbelt inertial reel mounting points behind the rear turret tops.  We will then locate captive nuts for the harnesses and the whole thing will then be welded up by them to ensure that it is solid.  For the front mounts we will drill though the floor and gearbox tunnel and then locate steel spreader plates with captive nuts on the outside to allow harness mountings to be fitted.  This meets with current FIA regulations so I am happy that it will be fine for track days.  He has a set of 2” harnesses that I can borrow, for as long as needed, and also has a seat I can borrow.  We were looking at how we could mount this and scoped out a number of options.  Because I want to retain the ability to have different people drive the car the seat needs to be on runners but he has a set of MX5 runners that are very low and flat so that mounting plates for bucket seats bolt straight to the top.  These would be fitted to the floor in the same manner as the harnesses using steel spreader plates.  This means that I could run the current passenger bucket and borrow his nice drivers one in time for my first track day, hopefully!  That has been booked for Brands Hatch on the 28th of next month so time is now officially against me!  Still life wouldn’t be fun without a challenge or two!
More as I get it,
Jon
