Author Topic: MK 3 GTI 5 STUD TO 4 STUD CONVERSION  (Read 23650 times)
Offline vee-dub90
  • mk3 GTI 16V next year.
Re: MK 3 GTI 5 STUD TO 4 STUD CONVERSION
« Reply #30 on: 23 September 2009, 23:33 »
 :undecided:
Offline vee-dub90
« Reply #32 on: 23 September 2009, 23:41 »
actually, i dont know why lol.
Offline monzablue16v
« Reply #33 on: 23 September 2009, 23:42 »
Ah sorry no that was for something else, Vauxhell Meriva 4x100 and 284mm are the nearest you will get :)
« Reply #34 on: 23 September 2009, 23:45 »
Only really matters if it's a VR with 288mm brakes tbh. I had a set which is why I looked into it didn't want to go 5 stud and widetrack on the Flog :) centre bores may differ and iirc  fiat coupe turbo brakes may be the same :)
Offline vee-dub90
« Reply #36 on: 24 September 2009, 10:06 »
Depends what size brakes you have, if they are 280mm then corrado or golf G60 ones will fit onto a 4 stud hub, if they are 256 then 4 stud GTI ones will fit, if they are the 288mm VR6 ones then there are a set from I believe a cavalier turbo or calibra that are 288mm and 4x100 :)
this doesnt work if you press 4 stud hubs into 5 stud bearing carriers, the disc offset is different hence why I said about re-drilling the 5 stud discs.
4 stud disc:
5 stud disc:
« Last Edit: 24 September 2009, 10:10 by rubjonny »
« Reply #37 on: 24 September 2009, 10:12 »
http://vapmotorsports.com/product_details.php?category_id=284&item_id=130
this wont work either if the op retains the 5 stud bearing carriers with 4 stud hubs pressed in. As above, the disc offset is different so the calipers & discs wont fit together. Need to redrill a 5 stud 288 disc to 4x100
Offline smeg760
« Reply #38 on: 24 September 2009, 14:26 »
Yeah i see what your saying So 4 stud hub press it is and a wee bit of re drilling .
So for the rear i would need to split the hub of a mk2 16v or perhaps a passat ?
ps I really didnt expect such a response this forum is soooo gurd.
« Reply #39 on: 24 September 2009, 14:51 »
for the rear its easy, just fit 4 stud rear discs to your existing stubbies :)
biggest dificulty will probasbly getting the carrier bolts off, they can be a total nightmare
