Author Topic: banging suspension  (Read 1884 times)
Offline DUNNY
banging suspension
« on: 17 September 2004, 19:41 »
can any one help i've got a mk3 20ltr 8v and its been lowererd i have 15" rims but when i go over a bump sometimes theres a loud bang-knock coming from the back shocker i've been told its where the car has been lowererd but i've seen plenty as low it been dropped about 20mm lower than standard i have changed the springs but no better the man at garage said its bottoming out on the bump stops but i cant see that would make a bang-knocking noise and sometimes i can feel it through the floor its really starting to pi** me off hope you guys can help ??? >:(
Offline carrie
  • i can see into your soul and its not good
Re: banging suspension
« Reply #1 on: 17 September 2004, 19:43 »
are the rubber bump stops missing?
SAY YOU LOVE SATIN?, NO SATAN, ITS SATAN
Offline DUNNY
« Reply #2 on: 17 September 2004, 19:47 »
they are still there apparently theyve been cut down dont know why
Offline mozzer
« Reply #3 on: 25 September 2004, 12:41 »
It will be the rear bushes that are worn out. I believe this is a common problem. Also check the front bushes as these will be more than likely on their way out also. hope this helps.
Offline DUNNY
« Reply #4 on: 25 September 2004, 19:56 »
is it the axle bushes???
