Author Topic: What is the normal oil operating temp?  (Read 20060 times)
Offline keelaw
  • It's here!
« on: 20 September 2009, 18:48 »
I've been through the manual and can't find anything on this topic, so thought I'd give you guys a go.
My oil temp at its highest seems to be just over 100 degrees C.  Is this the normal/ optimum temp?
At what temp can I start driving "enthusiastically"?  And what temp is too high?
Guidance appreciated  :smiley:
Mk6 Golf GTI 5dr, DBP, Monza Shadow, Xenons, ACC, RCD510, Park Assist, Camera, Lux pack.... and now bluetooth.... and now DSG!
Offline simonpolly
Re: What is the normal oil operating temp?
« Reply #1 on: 20 September 2009, 18:53 »
Mine seems to hover around 98-105c when the engine has been running for some time,i wait untill its around 95c and water/engine temp is at middle position (where it stays when warm) untill i give it some stick
Golfgti build quality is average at best.
« Reply #2 on: 20 September 2009, 18:57 »
Ditto ^^^^
Ideally you want to keep your oil under about 120 deg going from when I used to have mk2 GTIs which were the last ones to have an oil temp readout on the MFA.
Modern oils are very much better than the old oils though but then again the GTIs have turbos and put out a lot more power than in days of old so the oil gets put under a lot of stress.
More importantly, I think, is to make sure your turbo cools down before switching the engine off when you're been running the car at speed.
I'm sure T_T will be along to put us right once and for all....... :smiley:
Offline howlingmoon
« Reply #3 on: 20 September 2009, 19:46 »
Hi, my oil temp readings will depend on what speed I am going. At 80 -110km/h my temp hovers between  98 - 105 degrees. But at 140 - 160 km/h, the temp hovers between 106 - 108 degrees...
Hope this helps!
HM
GTI Mk6 United Grey, 18" Monza Shadows, RNS310, Executive Package, ACC
Offline gossa
« Reply #4 on: 20 September 2009, 22:49 »
Just over 100 for me, TT said start driving enthusiastically after about 85 I think.
Offline FroGTI
  • Wheel nut
« Reply #5 on: 21 September 2009, 12:47 »
Yet to see higher than 101.
Offline jdjd
« Reply #6 on: 21 September 2009, 12:52 »
Seen up to 106 on mine  :huh:
Offline DL
« Reply #7 on: 21 September 2009, 12:57 »
saw 143 on mine.............oh sorry that was the speedo :wink:
Offline GolfTi
  • ..gotta feel for my automobile..
« Reply #8 on: 21 September 2009, 13:06 »
Hope it was verified by GPS. :wink:
Mk7 GTI. DBP, DCC, Winter pack. Mine since new, July 2013.
GTI no. 4. Golf no. 5.  VW no. 7.
Offline Hairy Porter
« Reply #9 on: 21 September 2009, 15:39 »
You lucky blighters, oil temp.
Do you get oil pressure as well?
