Author Topic: Mk4 Suspension problems  (Read 1688 times)
Offline Phil.O
« on: 20 September 2009, 10:28 »
Hi all,
been talking about this is the mk4 section and can't work anything out so thought i'd drop a note in here and see if anyone else has any ideas,
recently put a set of 18's on and the drivers side wheel now rubs a little when i go over bumps, the car is lowered by 40mm but since it's started rubbing i've had a closer look and also others have commented that the drivers side sits a couple mm lower than the passenger side,
i've checked that the hubs are both bolted at the same height (they have locating holes so no chance of error there) and also check all of the arch lining,
i'm not really sure what else to check,
any advice or help would be great,
Phil
a work in progress......someday i might think i'm happy with a car....maybe
so far: 40mm Gmax lowering kit, upper and lower S3 strut braces, pipercross panel filter, Smoothed air box and 18" Audi R8 reps
gtigolfthree
Re: Mk4 Suspension problems
« Reply #1 on: 20 September 2009, 10:55 »
Whats the size of the tyres ?
« Last Edit: 20 September 2009, 11:00 by gtigolfthree »
Offline Phil.O
« Reply #2 on: 20 September 2009, 11:01 »
225/40 R18,
nothing over the top and there are people running them on a lower setup  :undecided:
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 20 September 2009, 11:11 »
driver weight.. cut back on the mcdonalds :tongue: :grin:
Offline Phil.O
« Reply #4 on: 20 September 2009, 11:15 »
............ :huh:
Offline rig-pig
« Reply #5 on: 25 September 2009, 08:08 »
as said the drivers side will sit slightly lower than the rest due to driver weight because there is always someone on that side of the car all the time that spring will always sit lower whether there is someone in the car or not, you also have the engine on that side as well which give's you the slight difference most cars are like this unless you have coil-overs and you can adjust it but don't worry this is normal as long as you have checked to make sure all is well under the car the other springs will settle down over a few months
hope you can understand my jabbering
craig
no man can eat 50 eggs
mk3 mondeo
ZX7r
