Author Topic: New mkIII owner  (Read 3663 times)
Offline kr1s77
New mkIII owner
« on: 17 September 2004, 11:47 »
Jus upgraded to a golf mk3 2.0 Gti 8v 1997 P 5 Dr. enjoying it very much, but it has cut out a few times while driving this week, more time its when i'm slowing down. Not sure if its me or the car?
Gonna put some pics up let me know what you think
ASV 1.9 TDI 110
Offline Len
Re: New mkIII owner
« Reply #1 on: 17 September 2004, 11:51 »
Oh u probably got the Mk 3 "disease" then mate.
Try the relays - cutting out is the fuel pump relay i think.
www.sas.org.uk
www.the-ace.org.uk
Offline Bog Standard
Re: New mkIII owner
« Reply #2 on: 17 September 2004, 20:47 »
Don't forget the basics.  When it happened to me, I thought I'd be cleaning out fuel system components and changing relays, but after I changed the plugs, oil and filters (oil, air, fuel and even pollen!), it's been fine.
Offline kr1s77
Re: New mkIII owner
« Reply #3 on: 18 September 2004, 08:03 »
Jus got in from work!!
thanx for the response  ;D. i'm gonna try the relay first (?7.51 from euro car parts), then if it carries on then i'll do a mini service. Well according to the service book, it had a 10k service (dont know what that involves) about 1500 miles ago. Oh by the way, where is the rely located (i know it sounds stupid, i havent looked for them yet).
once again thanx
ASV 1.9 TDI 110
redcarboy
Re: New mkIII owner
« Reply #4 on: 18 September 2004, 08:57 »
Relays located above fusebox beneath your steering column.welcome to the forum old chap. ;D
Offline richellis
Re: New mkIII owner
« Reply #5 on: 18 September 2004, 20:23 »
Try the throttle body. may need a clean! Herd the crank sensor playes up. at near ?150 try other stuff first ;D
MK3 Golf GTI
Offline kr1s77
Re: New mkIII owner
« Reply #6 on: 22 September 2004, 00:26 »
Changed the fuel pump relay, no 24 yesterday. Thought that did it,but no, jus cut out about 20 mins ago. put my amp in yesterday, that wouldn't affect the relay would it?????
« Last Edit: 22 September 2004, 00:28 by kr1s77 »
ASV 1.9 TDI 110
Offline 8vgti
Re: New mkIII owner
« Reply #7 on: 22 September 2004, 13:30 »
Numerous cures for this problem as it could be numerous things!! (do a search for previous topics). Initial problem on mine was cured by replacing relay 30 (hall sender relay..I think). Stalling when approaching traffic lights was cured by a can of powerboost cleaner in the throttle bodies. Try these first as relatively cheap fixes. www.ecotekplc.co.uk.
Offline kr1s77
Re: New mkIII owner
« Reply #8 on: 01 October 2004, 13:10 »
i can't find relay 30 for the hall sender .
Quote
ASV 1.9 TDI 110
mowgli
Re: New mkIII owner
« Reply #9 on: 01 October 2004, 17:18 »
This might help:
http://www.golfgtiforum.co.uk/index.php?topic=13291.0
It might be best to replace everything if it costs IRO ?60 to get a diagnostic check, plus, you will have brand new electrics ready for winter.
