Author Topic: Stiff Clutches!  (Read 1322 times)
Offline elmo2552
Stiff Clutches!
« on: 18 September 2009, 11:30 »
I am looking at a '98 Golf GTI in my local garage. When I took it for a test drive that clutch was mega stiff, the gears change fine but the pedal needs pressing v.hard. I am a bit wary as have had probs with a similar aged GTI in the past. Can anyone advise if they think it wud mean replacing the clutch complately (in which case I wont bother-car is only £2000). Any help VERY much appreciated
Re: Stiff Clutches!
« Reply #1 on: 18 September 2009, 12:23 »
If it is a mk3 then it could be a cable issue, if it is hydraulic then it does sound clutch on its way out.
Offline Diamond Hell
  • Opinions я Us
Re: Stiff Clutches!
« Reply #2 on: 18 September 2009, 13:38 »
What's the model?
gtigolfthree
Re: Stiff Clutches!
« Reply #3 on: 18 September 2009, 20:43 »
Tell them you may be interested in the car if the clutch worked properly.  :smiley: Welcome to the site by the way.
Offline gazpowells
Re: Stiff Clutches!
« Reply #4 on: 21 September 2009, 19:19 »
+1
Offline boneybradley
  • Back in a Mk3...
Re: Stiff Clutches!
« Reply #5 on: 22 September 2009, 23:12 »
if its a mk3 its expensive and if its a mk4 is still expensive!! (£1200 for a mk3 and £1600 for a mk4)
