Author Topic: bypass TB heating?  (Read 10370 times)
Offline Khare
  • The bear that khares
Re: bypass TB heating?
« Reply #50 on: 18 September 2009, 15:15 »
what did you do with the other pipe...I don't quite understand you're method but I guess until I inspect the hoses then I can't say anything.
Offline axewielder
  • 95 dragon 8v
« Reply #51 on: 18 September 2009, 15:26 »
put it in the boot lol, nothing goes to the tb anymore, the coolant goes straight from the front of the block to the exp tank as in the green line
Offline Ess_Three
« Reply #52 on: 18 September 2009, 15:52 »
Can anyone post some pics?
It's easier to suss out for us non-8v owners if there are some pics.
..but gaining motorcycles.
Offline axewielder
  • 95 dragon 8v
« Reply #53 on: 18 September 2009, 15:56 »
Offline Ess_Three
« Reply #54 on: 18 September 2009, 16:01 »
http://www.facebook.com/photo.php?pid=437451&l=beb2ec8bbc&id=1641456246
 can you open this link? doesnt work as img?
I can...
But was hoping for one a little closer up to the TB!
There should be a supply and return line...is there a 3rd?
Offline axewielder
  • 95 dragon 8v
« Reply #55 on: 18 September 2009, 16:06 »
you just remove both from the tb + have one going where the green one does on the pic, get it??
Offline axewielder
  • 95 dragon 8v
« Reply #56 on: 18 September 2009, 16:08 »
shows the brass thing the pipes used to conncet to on the right, that are now just left with nothing on.
Offline Khare
« Reply #57 on: 18 September 2009, 16:10 »
Done it you're way axewielder. Works perfectly.
Ess, basically there are 2 pipes going to tb, one from front head flange and the small one from header tank. I unclipped the one from front flange to tb, and connected it so instead of from flange > tb, it now goes flange > header tank. It replaces the header tank small line.
gtigolfthree
« Reply #58 on: 18 September 2009, 16:12 »
Yes but does it give you more torque?  :grin: :laugh: :grin:
Offline Khare
« Reply #59 on: 18 September 2009, 16:15 »
Not driven it yet  :tongue:
Will try it out in a bit, curently waiting for a call.
Mind you from reading up, you only notice a difference on hot days, so gotta wait till next summer to try it out  :grin:
