Author Topic: bypass TB heating?  (Read 10371 times)
Offline Khare
  • The bear that khares
Re: bypass TB heating?
« Reply #40 on: 18 September 2009, 13:30 »
Have to dig out my RR read outs then! Hmpft!
Bet my 16v is more than 132!
and waits....
Offline Len
« Reply #41 on: 18 September 2009, 13:34 »
and waits....
................. and waits!
A very long time!
At home somewhere when I can be arsed to find em! Probably for the 3rd Oct!
www.sas.org.uk
www.the-ace.org.uk
Offline Khare
« Reply #42 on: 18 September 2009, 13:38 »
 :grin: :grin:
Offline axewielder
  • 95 dragon 8v
« Reply #43 on: 18 September 2009, 14:04 »
chill out guys :grin: thanks for all the input everyone even the old 16vs8 rearing its ugly head
Offline Khare
« Reply #44 on: 18 September 2009, 14:50 »
Had a look today under the bonnet and the 2 hoses are in a pretty awkward position, so rather than a straight bit of pipe I shall need an "U" shaped pipe, size is about 7 or 8mm, not sure. For best access gotta remove the cam cover, although it COULD be done with just removing the intake pipe and one of the brackets from the cam cover to the top of the manifold.
Offline Ess_Three
« Reply #45 on: 18 September 2009, 15:01 »
I knocked up a job lot of bypass pipes out of 3/8"OD Stainless Instrument Tubing, machined down by 1mm at the ends, and bent using a pipe bender.
If anyone is in the Instrument trade, maybe they could knock you one up...or if you need to buy tubing, 3/8" stainless works a treat.
..but gaining motorcycles.
Offline axewielder
  • 95 dragon 8v
« Reply #46 on: 18 September 2009, 15:03 »
really, i did it last night with my leatherman in 5 mins, did remove the left inlet mani braket thing, i just completely got rid of one pipe+ the other goes from front of block to expansion tank. just left the tb with nothing connected. make any sense?
where does this go??
Offline Khare
« Reply #47 on: 18 September 2009, 15:06 »
axewielder, any pics?
Ess, 3/8" (10mm) sounds about right. I'll try and get U shaped copper piper or s/s pipe and try it out.
Offline axewielder
  • 95 dragon 8v
« Reply #48 on: 18 September 2009, 15:09 »
Offline axewielder
  • 95 dragon 8v
« Reply #49 on: 18 September 2009, 15:09 »
i dont understand where the copper pipe would go??
