Author Topic: Mk3 2.0 GTi strange "chooo" sound from engine bay when accelerating.  (Read 2771 times)
Offline Mr.Tom
I mentioned it before somewhere, but have better diagnosed it (a little)
Whenever I put the accellerator pedal down while driving, I get a strange sort of soft "chooo" sound from somewhere in the engine bay. Best guess is back against the firewall on the driver side.
It also happens when I turn the engine off.
Almost like saying "tissue" quietly with your teeth together, best way I can think of describing it :)
Can press the pedal repeatedly and it will do it each time with the engine running.
Any ideas?
MK3 GTI 2.0 late '96
Offline Paul86S2
Vacuum leak? Check all the vacuum pipes to make sure they are connected properly and are not split.
Paul
Offline Len
Perhaps its a turbo!  :grin:
Could be the vac hose to the brake servo?
www.sas.org.uk
www.the-ace.org.uk
Offline Mr.Tom
Wish it was :D
Will take a look at the hoses.
Cheers.
Offline A7 UFO
how many people read this
Quote
and then sat there quietly doing it?
Offline Mr.Tom
Think I found it.
It's a pipe that runs from the right hand end of the throttle body, round the back of it, then behind the brake fluid reservoir.
On 1A.6 of the haynes manual, it runs from point 14 of the bottom picture, round the back of point 4. So a bugger to get to :/
It is split at the end behind the brake fluid reservoir.
What should I be ordering?
Offline Mr.Tom
Okay. It was the break servo pipe apparently. Got it out and popped it over to the local garage. They are ordering me one now :)
Offline Mr.Tom
What does it actually do? There is a little valve at the intake end. The engine cuts out of it is disconnected.
But I don't understand what it is for :)
Offline Len
Star for Lenny!  :grin:
Its a vacuum hose! It assists the brake servo!
www.sas.org.uk
www.the-ace.org.uk
Offline mumbles
Quote
 :grin:    :lipsrsealed:
Wouldn't be fun if it was easy, but does it have to be this much fun?
Audi A4 Sport
