Author Topic: Driving Crazy!!!  (Read 10057 times)
Offline daddy kool
Driving Crazy!!!
« on: 17 September 2009, 11:10 »
  My rear parking sensors keep bleeping when in reverse ,even when there's nothing around.
 It drives me crazy, anyone had this prob.
I have done a search on here to no avail.
Offline jaydubveedub
Re: Driving Crazy!!!
« Reply #1 on: 17 September 2009, 11:18 »
Sounds like one of the sensors has packed up. Has it been washed with a pressure washer? These can buggar the sensors.
You could probably find out which one is faulty by unplugging each one in turn and seeing when the fault stops.
Just a suggestions, could be something else.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline DPG
« Reply #2 on: 17 September 2009, 12:25 »
My Z4 used to do this.
Everytime the car was in reverse it would constantly beep.
So annoying
Offline synnea
« Reply #3 on: 17 September 2009, 14:51 »
Mine did it once or twice when there was some dirt stuck. I just 'blew' over the sensor and that sorted it for me.
Perhaps in your case yours may be damaged.
R32 : DBP : Lux Pack : Winter Pack : Cruise : Leather : Parking Sensors : Rear Tints : Armrest : RNS 510 : Ipod MediaIn : FreeView Tuner : VagCom
Offline Teutonic_Tamer
« Reply #4 on: 19 September 2009, 22:15 »
You need to VCDS it - the fault code will tell you exactly which one has failed.
I feel like a homo
Offline AliBailey88
« Reply #5 on: 19 September 2009, 22:46 »
i know with renaults you can tell which one is faulty as when the car is in reverse you can feel the sensors pulsing if you touch them with the tip of your finger, the duff one wont be pulsing
Offline daddy kool
« Reply #6 on: 20 September 2009, 19:45 »
Found one sensor had blistering paint ,scratched it off and all seems ok,     Cheers!!!
