Author Topic: what seats fit a mk1 cabby???  (Read 7843 times)
Offline steble
« on: 16 September 2009, 01:17 »
what golf seats are a stright fit for a mk1 cabby my mum keeps complaining about the seats in hers cos they are a bit knackered lol whats she expect from a 21 year old car ha ha ha
Offline deanpompey
Re: what seats fit a mk1 cabby???
« Reply #1 on: 16 September 2009, 07:20 »
rears i believe is pretty much cabby only.
fronts is mk1 golf, scirrocco and think corrado seats possibly?
mk2 seats will physically fit, but the slider handle doesnt line up properly i believe, so they will have to be fixed in permanent position.
 or pretty much anything if your able to do some fabrication on the subframes.
« Reply #2 on: 16 September 2009, 09:14 »
mk1, mk2, scirocco and corrado front seats all fit, as do height adjustible polo mk3.  mk3 seats fit if you swap over the old cabby seat base frame also.
the slider issue depends on the age of the cabby, in about 84ish they changed to the MK2 side which means later seats are a direct fitr, if its earlier than that then only mk1 items are a direct fit.  either way if you fit the wrong type seat the only issue is the slider wont work, you may also be able to swap the cabby fdrame over to the new seat dependign on what it is. if its a pre-90 mk2 or MK3 polo then the frame should swap, cabby frames wont fit post 90 mk2 seats or scirocco/corrado.
another option is to swap over the slider handle, easy with a little trickery under the seat. however if the height adjust handle is on the front this wont work as the handle is where you want the slide lever to be!  You can get height adjust bases with the handle on the side though, these are perfect for the swap trick.
Offline MK1 Ali!!
« Reply #3 on: 30 December 2009, 00:03 »
mk2's fit fine!!!
