Author Topic: 8v tuning guide question...setting up timing  (Read 1868 times)
Offline Gloves88
« on: 13 September 2009, 22:46 »
Just a quick question regarding setting up the timing...
Is this correct,
- Turn on car, bring up to temp
- Remove blue temp sensor
- Bring up to 2-2.5k....and hold it here?? setting 6 deg BTDC
- Replace blue temp sensor
- Bring back to 2-2.5k and check timing has advanced 30 deg
If it has then fine, timing is now complete??
Is this the correct way of setting up the timing?
Offline fused
Re: 8v tuning guide question...setting up timing
« Reply #1 on: 13 September 2009, 22:58 »
Offline Gloves88
« Reply #2 on: 13 September 2009, 23:21 »
http://www.golfgtiforum.co.uk/index.php?topic=33253.0
it's in the maintance section   :rolleyes:
Thats what I've been refering to...
Its mainly this line that I was unsure of:
Offline weazgti
« Reply #3 on: 13 September 2009, 23:27 »
Turning dizzy untill the notch on the gearbox lines up with the 6 degree btdc on flywheel,with a timing light of course.
Offline Gloves88
« Reply #4 on: 14 September 2009, 08:04 »
So do you hold the revs at 2-2.5k while setting 6 deg?
Offline weazgti
« Reply #5 on: 14 September 2009, 08:58 »
Yes mate,i got someone to hold it there while i turned dizzy.
I only did mine few weeks ago using the guide on here,i was bit confused bout the advance when you plug the blue sensor back in and rev it but was told thats what its supposed to do.Mine run so much better after doing the timing,even though the co has not been done in its life (still has tamperproof plug in the air flow meter)
Offline Gloves88
« Reply #6 on: 14 September 2009, 13:09 »
Cheers for clearing that up for me :)
« Reply #7 on: 15 September 2009, 11:29 »
yep thats how you do it, when I'm setting it up i pop a few credit cards into the throttle stop to hold the throttle open, add/remove cards till its at 2.25k and fiddle with the dizzy. once its lined up recheck the revs and adjust the cards to suit, then recheck the timing mark.
Offline weazgti
« Reply #8 on: 15 September 2009, 13:34 »
RJ are the old colurtune kits good enough to set up co?
« Reply #9 on: 15 September 2009, 15:10 »
dont know tbh, think they're more for old skool carb/k-jet stuff
