Author Topic: Mk1 Golf Gearbox oil change  (Read 7641 times)
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« on: 15 September 2004, 20:13 »
I need some help....
Can someone tell me where the hell you change the oil in gearbox on Mk1 golf cab? I've looked in book but I can't see it....? >:(
thanks...
« Last Edit: 15 September 2004, 20:16 by Madone »
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
vwsystems
Re: Mk1 Golf Gearbox oil change
« Reply #1 on: 15 September 2004, 20:58 »
there are 2 plugs 1 the fill plug is on the side of the box which you will get at if you lock your wheels over to the left it is at the back of the front passanger side wheel arch......
and the drain plug is under the the box it is under the diff.... basicly where the drive shafts enter the box its under this it will look like the fill plug 17mm allen key how much oil you need i dont know as ive only got the nk 2 book.....
normaly you fill the box until the oil starts to run back out of the fill hole! make sure it does run out and its not running back out because your putting it in too fast...
and early gearboxes had a different fill technique.........
something like you have to fill it up normal and then add 250ml or 500ml through the speedo cable hole!
because of the fill put is too low..... on later models they revised this.......
someone should know more about this...
use a synthetic oil..... this will help stop cold crunch gear changes and will help the box last longer
Offline Madone_si
« Reply #2 on: 15 September 2004, 21:07 »
thanks.  :)
SOLD - BLACK SOY 92
Offline Ryan S
« Reply #3 on: 11 October 2004, 14:59 »
How long does this take then - to change the oil in a gearbox??
(for someone who knows what they're doing)
Offline Gambit
« Reply #4 on: 11 October 2004, 15:51 »
about the same amount of time it'd take to do a std oil change.
