Author Topic: Engien Mounts For A 1.8T  (Read 2030 times)
Offline harney123
« on: 13 September 2009, 13:55 »
hey guys i've got all the bits i need for  my 1.8T conversion but i don't know what to do about engine mounts? does anyone know? and has anyone done this? on QPENG they say to use uprated MK2 enigine mounts?
thanks lads
Offline dubvrs
Re: Engien Mounts For A 1.8T
« Reply #1 on: 13 September 2009, 20:03 »
Golf mk2 G60 and 16v have uprated engine mounts as standard compared to other mk2's. I just used a new set of 16v ones on my 20v conversion.
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 13 September 2009, 20:30 »
Get a Cordoba subframe and get it stitch-welded, which will make it a lot stiffer.
The mount at the back of this subframe is different to the Golf2 ones, but should be better for it.  You can cut off the rear tabs,unless you want to bolt them up through the floor to add extra rigidity again.
I would avoid using a solid front mount, especially in view of you using the car as a daily.  Golf2 1.3 rear gearbox mount should be sufficient - it's solid rubber.
Offline harney123
« Reply #3 on: 13 September 2009, 21:47 »
well i should be using Vibratechnics mounts they seem rather good, but i meant the mounting brackets from the car to the block i just cant see how they bolt on!
Offline dubvrs
« Reply #4 on: 13 September 2009, 22:05 »
Original alloy mount bolted on back of 20v so oem mk2 mount can be used.
I used a Passat GT 2.0 16v box with G60 flywheel and uprated VR6 corrado clutch. Used original mk2 mounts.
End result
Offline harney123
« Reply #5 on: 14 September 2009, 11:37 »
thanks for the pics mate much appreciated :D big help indeed :)
another question did you have to re-route the turbo piping because mine seems to be covering the mounting point and it doesn't seem to on yours lol
thanks
Offline harney123
« Reply #6 on: 14 September 2009, 11:38 »
also is that an 02a box your using? because it looks identical to mine, and if it is how good is it?
thanks again lol
Offline Ben Lessani
« Reply #7 on: 14 September 2009, 13:08 »
:drool:
Offline dubvrs
« Reply #8 on: 14 September 2009, 20:54 »
My box was a 02a. Was fine with the power just slightly short gearing.
I removed all the boost pipes and used universal items to tidy things up a bit.
Used a sprinter intercooler.
All the pics i have of the pipework.
Offline madmanluke
« Reply #9 on: 14 September 2009, 21:02 »
I ont want to hijak the thread or create a new one. Do you guys use a 1.8t mk2 web page at all? Like mk2vr6.com?
I am undergoing the transplant in the next few weeks and want to read up about more things like engine mounts etc as above.
