Author Topic: fuel pump set up for 16v conversion???  (Read 5400 times)
Offline deanpompey
« on: 13 September 2009, 08:33 »
ok so engines in, now kinda confused as to what fuel pump set up i need (car used to be a carb'er).
as i understand it, i need an in tank lift pump/sender unit either from a mk2 16v golf or a 16v polo etc and also a mk2 16v under body fuel pump.
keep seeing digifant (8v) set ups for sale,would that work? like this:
 http://cgi.ebay.co.uk/VW-Golf-GTI-Mk2-90-Spec-Digifant-Fuel-Pump-Assembly_W0QQitemZ250494525897QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3a52a321c9&_trksid=p3286.c0.m14#ht_500wt_1182
or can i get an intank one like this?
or an electric one like this?
http://cgi.ebay.co.uk/Fuel-Pump-Audi-80-100-BMW-VW-Golf-Passat-Peugeot-Volvo_W0QQitemZ140311993662QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item20ab3f1d3e&_trksid=p3286.c0.m14#ht_1636wt_939
i really am getting confused now! can someone give me a full, simple list of whats needed please?!
would help massively!
cheers
Offline deanpompey
Re: fuel pump set up for 16v conversion???
« Reply #1 on: 14 September 2009, 16:48 »
come on peeps someone must be able to confirm this for me?
k jet in tank lift pump and under car pump and lines an im away right?
Offline danny_p
« Reply #2 on: 14 September 2009, 19:39 »
in tank pumps  are same  spec for digi and k jet.
if you are running K jet you MUST have a K jet under car pump.
if you are running Electronic injection ( any flavor ) as long as it isn't a boosted enigne the Digifant pump is fine, but you can use K jet pumps if you wish ( they are just over specked for NA use bit good with turbo lumps)
if running carbs  the lift pump allone is adiquate
all the VW's have gone bar 1.
Offline deanpompey
« Reply #3 on: 14 September 2009, 19:57 »
thank you danny. much appreciated mate
« Reply #4 on: 15 September 2009, 11:49 »
non of the MK2 stuff will work on a MK1, mk2 under car pump is too big and lift pump wont fit in the tank.
what you need is a MK1 injection under car pump, accumulator & lines, plus associated brackets. make sure its from a k-jet model as very last cabby models were digifant.  The last link there looks to be the correct fuel pump, just need the lines & accumulator + brackets to match.
Then you have 2 choices:
1. replace fuel tank for MK1 tintop GTI item
2. fit later MK1 cabby/scirocco lift pump, reservoir and lines to the pump into your carby tank
« Last Edit: 15 September 2009, 11:51 by rubjonny »
Offline Tucker
« Reply #5 on: 19 September 2009, 16:35 »
As rubjonny said.
Mine was a 1.5 carb. Used mk1 GTI tank and pump that sits next to it.
Carb tank uses lift pump in the top. GTi tank just the sender in the top and hole at the bottom for the supply for the pump
Thanks
Tucker
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
