Hi Folks,
Need some advice as I'm now stuck, my 96 VR6 has been cracking, you can feel and hear it, when turning the steering wheel. Once he wheel is 'turned' i.e. to go round a corner the cracking stops. If the car is sitting stationary I can still hear the cracking whilst turning the wheel.
Ok so to solve the problem and just because the work was needed the following work has been carried out:
New steering rack (recon)
Steering column removed and bushes replaced
Track rod ends replaced
Lower arms on both sides replaced + bush naturally
Anti Roll bar bushes
New shocks + springs all round
New top mounts + strut bearing
After all the work she drives beatifully but is still cracking! (and not in a good way
Suggestions please as I'm stuck :embarassed: and skint
UPDATE : Well thanks to the helpful chaps on this forum I've tracked the little blighter down. The problem in the end was ....... The steering rack was MOVING in its rubber clamps/mounts. The 'Creaking/Cracking' was the rubber 'sticking' then slipping to the rack as it slide around!
