Cosmetic and bodywork matters
Best caliper paint?
Topic: Best caliper paint? (Read 1995 times)
JDM82
Here all the time
Best caliper paint?
06 September 2009, 18:49 »
What make is the best caliper paint? Does anyone know of any company/workshop in the north east (near newcastle) that paints calipers for you? I want a good job and Im sh!t when it comes to anything like this.
GOLF GTi - The legendary hot hatch
simonpolly
Re: Best caliper paint?
06 September 2009, 19:05 »
Hammerite is as good as anything else,cheaper than the paints that are supposed to be for calipers and probably alot better paint,just make sure they are clean,dust and grease free and away you go.
Golfgti build quality is average at best.
northeast_gti-t
Serious forum addict
"1.8T AGU"
06 September 2009, 19:58 »
i used the foliatec brake caliper paint kit has all the stuff you need inside the box i.e brake cleaner,paint and hardener i also applied some clearcoat laquer to mine while drying to give it some extra shine
2000 Mkiv GTi 1.8T AGU
Deano2711
1992 VR6
06 September 2009, 21:02 »
Did mine recently and just used the standard tins of paint you buy from car spares shops. Used primer first (one coat) then paint (two coats) then finished off with two coats of lacquer. They look a treat and while I am no expert at painting just remember to spray from about twelve inchs away and apply thin coats of paint to avoid runs. Took me about two hours total to paint all calipers. Had the car jet washed every week since and they still look great due to the lacquer. Give it a try and just start off by using a wire brush to clean them up first. I did mine with the pads still intact as I very carefully masked off everything and all I removed is the retaining clip on the front calipers.
Cheers Deano
Ben Lessani
The poor mans MK2 Haynes author
06 September 2009, 21:11 »
Normal hammerite +1
MK3GTI_16Valve
Here all the time
07 September 2009, 14:47 »
red calipers on my silver would look the bizz
Len
10k hero
Reply #6 on:
07 September 2009, 14:54 »
Smooth Hammerite! You can also mix colours!
www.sas.org.uk
www.the-ace.org.uk
Best caliper paint?
