Author Topic: Wooden Dash  (Read 3040 times)
Offline ipswich1.8t
Wooden Dash
« on: 05 September 2009, 13:56 »
Well i've just managed to get hold of some bora sport interior bits to git rid of all the loverly wood in mine ...question is whats the easiest way of changing them ?..Is there a guide to this somewhere ?
I've managed to do the door handles , and i've got a new gear knob already its doing the rest that is confusing me ..di i have to take all the centre console out to do this ?...
Also at some point i want to change the stereo as well so would i be better off doing it all in one go , as i'm going for a single din size one , as i have one spare , so what else do i need for that as well ...?
Thanks ..
Offline johnson6672
Re: Wooden Dash
« Reply #1 on: 05 September 2009, 14:09 »
There is a how to in the maint section somewhere, but you don't have to remove the centre consol to do it, everthing just slides, unclips or is screwed on.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wooden Dash
« Reply #2 on: 05 September 2009, 14:58 »
did you win it all off ebay?
side stips are the hardest ones, they pull off downwards BUT there is a clips holding them on. If you look at the small lugs on the back of the strips you are putting back on it will be the 2nd one from the top so you need a screwdriver to prise it off.
It will make sense if you can find a pic with the strips off
Offline linz
  • vee-dub
Re: Wooden Dash
« Reply #3 on: 05 September 2009, 15:30 »
there not to bad i found doing mine pretty easy :) jus go an get stuck in an ul see ;)
Offline ipswich1.8t
Re: Wooden Dash
« Reply #4 on: 06 September 2009, 02:03 »
yeah it came from ebay ...
what about the cup holder front , does that just clip on as well , and the ashtray cover ?????
Offline jeynesey
  • Non VW but still VAG
Re: Wooden Dash
« Reply #5 on: 06 September 2009, 09:17 »
Offline Madmax
Re: Wooden Dash
« Reply #6 on: 06 September 2009, 09:30 »
http://www.golfgtiforum.co.uk/index.php?topic=92474.0
In that thread, with the part numbers is there a website you can order from or will you need to take them to a dealer?
Offline richw911
Re: Wooden Dash
« Reply #7 on: 06 September 2009, 10:58 »
Dealer is cheapest  :wink:
 http://bambergvr6.50megs.com/aluminum_trim_install.htm
Offline Madmax
Re: Wooden Dash
« Reply #8 on: 06 September 2009, 14:28 »
Thanks mate. Might order or i might just spray them myself. :)
Offline johnson6672
Re: Wooden Dash
« Reply #9 on: 06 September 2009, 15:23 »
just spray whats there, comes out nice, just have to drive around for a bit with no trim.
