Author Topic: got my 2 slow mk4 got a problem  (Read 1679 times)
Offline paul7278
  • boom boom problem solved!
« on: 05 September 2009, 10:56 »
well got my 2 slow last night everything was fine til this morning. i went to start it and it took age sto fire but once fired it was fine and will run perfectly. any ideas?
Offline richw911
Re: got my 2 slow mk4 got a problem
« Reply #1 on: 05 September 2009, 10:58 »
Any fault codes?
When was it last serviced? Plugs need replacing?
Offline paul7278
« Reply #2 on: 05 September 2009, 10:59 »
it had a recent service. might do the plugs anyway though. any other ideas? theres no managemnet light on
Offline johnson6672
« Reply #3 on: 05 September 2009, 11:01 »
I may just be one of those things, i have had it before then it never does it again, if it is like it all the time then i would start to worry but will probabley be something simple.
Also you don't alwayts get a light with a fault code.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline richw911
« Reply #4 on: 05 September 2009, 11:01 »
The main coil pack could be faulty? leads? sensors?  :undecided:
 Really need to scan it before spending any money on it  :wink:
Offline paul7278
« Reply #5 on: 05 September 2009, 11:02 »
ok thanks guys. ive got a fault reader at work so will plug it in and see. problem is when its warm its fine.
Offline johnson6672
« Reply #6 on: 05 September 2009, 11:03 »
Does it do it all the time or is it just this once? Not all readers will read vag either, what is it you have at work?
Offline paul7278
« Reply #7 on: 05 September 2009, 11:06 »
bosch i believe it read bmw etc for sure. ive only had it a day and that was the first time i started it from cold
Offline johnson6672
« Reply #8 on: 05 September 2009, 11:08 »
Get it connected up anyway i found out my heated mirrors don't work thanks to vag com, but i would see what its like tomorrow, where are you based?
Offline paul7278
« Reply #9 on: 05 September 2009, 11:09 »
cornwall mate i work at kwik fit
