Author Topic: leaky mk2  (Read 1765 times)
Offline mattthefinish
leaky mk2
« on: 04 September 2009, 16:56 »
I just came back from holiday to find my golf miserably wet inside - I didn't leave any windows open. Under the mats front and back on the floor is absolutely soaking passenger and drivers sides yet the carpet running down from the doors (where I assumed the leak would stem from) to the floor seem dry - quite a mystery. I'm assuming that if I just ignore the problem my car will start to stink like a rotten pond but anyone got any suggestions on tackling these kinds of issues...I don't fancy ripping all the carpet out to dry it off but I'm worried that new life will start to form if I don't deal with it?
Any help appreciated
Offline Dan34
  • VTEC Powerzzzz
Re: leaky mk2
« Reply #1 on: 04 September 2009, 16:59 »
open your bonnet and check under the scuttle panel near the wings, there are drain holes there and they sometimes get blocked and can cause this. hope this helps  :smiley:
Dan
Offline ianmaxtec
Re: leaky mk2
« Reply #2 on: 07 September 2009, 18:56 »
not sure if its related, but if i park my mk2 (3door) facing uphill in the rain, the rear passanger foot well has an inch of water in it. Never got to the bottom of he problem, I just park the car facing down, and it never happened again
Offline Reasty
  • Alpine white valver.
Re: leaky mk2
« Reply #3 on: 07 September 2009, 19:05 »
check the heater matrix as these can burst and flood the car,and as said check under the scuttle for blocked drainage holes.
Offline l333
  • mk2 8v....mk3 8v....mk3 16v.... who says im greedy
Re: leaky mk2
« Reply #4 on: 07 September 2009, 19:15 »
hi i had a leaky mk2 was a combination of crap in the scuttle panel and door membranes replaced and cleaned now lovely and dry :grin:
Offline The Mighty Elvi
  • I'm better than you today.
Re: leaky mk2
« Reply #5 on: 07 September 2009, 19:17 »
Also check the seal between the pollen filter and the metal (-assenger footwell puddle ), and the rubber grommet surrounding the throttle cable and bonnet release cable (Driver footwell puddle).  They are the most  likley to fill the footwells if the door membranes are intact.
I put  a bit of bearing grease all around the throttle/bonnet cable grommets and that seems to stop the leaks.
Offline sidecarphil
Re: leaky mk2
« Reply #6 on: 07 September 2009, 19:44 »
i like this fix  :grin: :grin: :grin:
Offline dan_apps
  • too low for british roads!
Re: leaky mk2
« Reply #7 on: 07 September 2009, 19:46 »
I LOL'D
Offline Ben Lessani
Re: leaky mk2
« Reply #8 on: 07 September 2009, 22:53 »
http://www.matey-matey.com/leak_prevention.shtml
alright, not a repost - but it gets answered often enough
Offline Dan34
  • VTEC Powerzzzz
Re: leaky mk2
« Reply #9 on: 07 September 2009, 23:12 »
LOL did you make that??  :grin:
Dan
