Author Topic: info needed on over-run cutoff valve  (Read 19026 times)
Offline Gambit
Re: info needed on over-run cutoff valve
« Reply #50 on: 08 November 2004, 09:40 »
saucer thing shouldnt cause any problems if not working. i ran my white 16v for about 18mths with it disconnected.
i changed the control unit on my 16v on sunday & it cured the current ISV problems i was having. but then i knew my control unit was shafted, where as u dont. they are a 5min job to change over though
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #51 on: 08 November 2004, 13:22 »
I need a control unit then :), if you know of one, please let me know!
Scrapies are sparce down here :(
Offline Gambit
« Reply #52 on: 08 November 2004, 13:57 »
do u not know anybody else with a 16v nearby that u could swap over modules just to test it?
Offline Deefadog
« Reply #53 on: 08 November 2004, 14:31 »
No, wish i did, testing would be so much easier!
Can i test it without swaping it? maybe disconnect it and see what happens, if there is no difference then i know it's knackered i suppose. But i still would have nothing to compare it to, so mabe not a good idea :(
Offline Gambit
« Reply #54 on: 08 November 2004, 14:58 »
the only way you know its knackered is if it wont idle on its own
with mine when you started the engine and let it idle it would just rev all the way up to 4k and just hold at that. hence how i knew it was banjo'd!
ring RadiCool VW. they are very reasonable i've used them loads of times to get parts sent over to me in N.Ireland and also in the Isle of Man
Radicool VW
Unit N, Long Meadow Works, Ringwood Rd, Three Legged Cross, Wimborne, Dorset BH21 6RD
Tel: 01202 823060
Offline Deefadog
« Reply #55 on: 08 November 2004, 15:42 »
Cheers for the contact, do they supply second hand parts?
Offline Gambit
« Reply #56 on: 08 November 2004, 15:53 »
yes they are VW breakers
and are very cheap also
Offline Deefadog
« Reply #57 on: 08 November 2004, 16:15 »
Nice one, thanks
I never new there were specialist breakers and ones that deliver! I just rang them!
?23 delivered for the isv controll unit & saucer pressure valve!
Bargain, thanks again
will let you know!
Offline Gambit
« Reply #58 on: 08 November 2004, 16:48 »
i told u they were cheap
are they taken credit card payments yet? last time i used them it was only cheque or postal order
to get at your ISV module u'll need to take out the 3 screws in the centre console. two are easy enough to find - one on each side and then there is one underneath the gearshift rubber cover thing that usually has people searching for a bit!!
Offline eyeletboy
« Reply #59 on: 08 November 2004, 16:51 »
if you want to check anything out on your valver,your welcome to have a look at my engine as i have got one now ;)
