Author Topic: info needed on over-run cutoff valve  (Read 18649 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 13 September 2004, 12:41 »
on my MK 16V!
What does it do? what is it connected to? what other (if any) valves switchs does it control?
if the elctrial connection is disconected would I lose power at all?
any info would be great
Thanks
Offline Deefadog
Re: info needed on over-run cutoff valve
« Reply #1 on: 14 September 2004, 11:46 »
sorry to seem impatient.
Anyone got any info or can point me in the right direction?
Thanks
Offline Gambit
« Reply #2 on: 14 September 2004, 17:17 »
no you wouldnt lose power.
basically all it does is keep the rev's that little bit higher for a fraction of a second when you come up of the gas saying for changin gear. it helps improve fuel economy by about 1mpg ::) but more importantly makes gear changin that little bit smoother.
the wee duffer (looks like a silver disc) on the back left hand corner of the airbox, sense's a vacuum when you come of the throttle it then opens the air tract runnin from the base of the airbox into the inlet tube and basically bypassing the airflow meter for that split second - if that makes any sense
Offline Deefadog
« Reply #3 on: 14 September 2004, 22:56 »
Thanks, this was the cause of all the other problems I had, kangaroing and a bad flat spot between idle and 2000 rpm. I have only disconected the electrical connecton at the moment, so does this little valve sound like it could do all that or is there another process involved that would cause the problems?
Is there a vag part number on the valve at all? as today i phoned my VAG dealers and they said "er we can't seem top find it on the computer, do you have a part number?"  -  Stupid gits :)
Offline Gambit
« Reply #4 on: 15 September 2004, 14:24 »
yes it has been known to cause problems - i wouldnt worry about it. it'll cost you an arm n a leg to replace
u'll probably find its not the we vacuum sensor but the actual air bypass valve connecting into the airbox as these are usually saturated in mucky oil that comes up the breather
Offline Deefadog
« Reply #5 on: 15 September 2004, 16:07 »
Aha, i see, is that part the the electrical connection connects into, it's about 4" high and has stumpy pipes coming from it if i remember?
Might be worth taking it apart and giving it a good clean, it's the part of the pipe system i have not cleaned, typical :)
Offline Gambit
« Reply #6 on: 15 September 2004, 16:14 »
it connects into the back of the airbox and the underside of the air intake pipe.
the pipes are about 1/2 inch in diameter, there is no electrical wires going into it. it only has a vacuum pipe running to that we duffer on the airbox.
its usually boggin with oil so be prepared for mucky hands
Offline Deefadog
« Reply #7 on: 15 September 2004, 16:45 »
right I see, I am confused now as i disconnected the electrical connection just up from that, it's two wires in black plastic housing with metal spring clip and plugs up into something straight upwards (which I thought was the over run cut-off valve), what does these wires control?
Offline Gambit
« Reply #8 on: 16 September 2004, 09:13 »
i dunno you've confused me also! i'll need to go look round an engine bay
Offline Deefadog
« Reply #9 on: 16 September 2004, 11:36 »
Thanks mate, I can't take pics at the mo, I'll try tonight and show exactly where it is.
take care
